Hi guys,
as as you can see I’ve managed to bend 4 pins or so on my brand new MoBo I’m sickened but hoping I can sort it. Would you say this is fixable? This will also have  9900k going in it 4909BEF4-C6A0-4144-B8B0-E0B834878649.thumb.jpeg.78c36f5fbac86bc4d8c4ca12feb786a1.jpeg
 CPU: i9 9900k @5.1ghz | GPU: Asus Strix 2080Ti OC | Cpu Cooler : Corsair H150i (360mm) | Motherboard: Gigabyte Aorus Pro Z390F  | RAM: G.Skill Trident Z RGB 32gb 3600Mhz CL16  | Boot / OS SSD : Samsung 970 Evo 500gb M.2 / Samsung 850 Evo 500Gb SSD / 1TB SEAGATE HDD Case: Corsair Obsidian 500d SE RGB | PSU: Evga SuperNova Platinum 8
https://linustechtips.com/topic/1058760-help-bending-back-pins/
7, 8, maybe even 9 if I'm looking at this correctly. As far as I can tell they don't look too horribly bent. Use a pin or needle, work slow and careful I think they're salvageable.
https://linustechtips.com/topic/1058760-help-bending-back-pins/#findComment-12518536
Okay I really hope so, I certainly won’t be over clocking the 9900k on this
https://linustechtips.com/topic/1058760-help-bending-back-pins/#findComment-12518541
