I am looking for help finding a case for a build I am putting together. I would like to use the H150i cooler, on a top mount, and the MSI - GeForce RTX 2080 8 GB DUKE Video Card. Therefore I need a case that has good airflow using the top mount, and can fit the GPU. Any suggestions, I prefer a darker colour scheme and a side glass panel if possible.
Thanks!
EDIT **ATX form factor**
https://linustechtips.com/topic/1057687-case-question/
24 minutes ago, FeaR418 said:
Doesnt the case top hurt top mounted rad performance?
not sure what you mean there because top mounting it is what you asked for, but I can tell you that the Meshify C is doesn't have enough length to hold 360mm up there nor the height for fitting any most radiators out there. At least the most common one from Asetek doesn't, as I know NZXT X62 doesn't fit.
Cooler Master H500 with mesh front will be my pick
Desktop benching:
https://linustechtips.com/topic/1057687-case-question/#findComment-12508688
21 minutes ago, Bearmann said:
I was looking at that - if that were the route to go, I would need to get some case fans i believe. Any recommendations?
https://linustechtips.com/topic/1057687-case-question/#findComment-12508826
I believe that Gamersnexus said that the top wouldnt be a good place in that case, as there isnt enough opening on the top.
https://linustechtips.com/topic/1057687-case-question/#findComment-12508831
Bling (RGB) or no bling? Here's a nice build in that case, but I would make the AIO the top intake, put 3 fans on the bottom as intakes to supply fresh air to the GPU, and make the side fans the exhaust.
www.youtube.com/watch?v=KU6vIDpNaxw
https://linustechtips.com/topic/1057687-case-question/#findComment-12509467
The Mastercase H500 only supports a 240 rad in the top, the H500P Mesh introduces the 360mm top compatibility.
@FeaR418 look into the Phanteks Enthoo Pro M TG
https://linustechtips.com/topic/1057687-case-question/#findComment-12509492
Either or are fine, just keep the costs reasonable!
Edit ** Those Corsair fans look cool, they're on the pricier side tho **
https://linustechtips.com/topic/1057687-case-question/#findComment-12510854
I think the slots are 120's/140's. At the most economical, some Arctic F14's (+/- PST)
Next maybe Noctua Redux or BeQuiet Pure Wings 2.
I think I saw some Corsairs on sale. Are you in the USA?
https://linustechtips.com/topic/1057687-case-question/#findComment-12510924
Canada! - The Corsair ones are on sale right now, but i most likely wont be purchasing this week.
https://linustechtips.com/topic/1057687-case-question/#findComment-12510926
