First cpu and heatsink installation
LTX
I just had the most annoying time installing my cpu and heatsink for my very first build.
first, the heatsink wouldnt sit properly, i made sure the backplate was protuding enough but it just wouldnt sit right.
second, I removed the heatsink in order to try replacing it AND THE RYZEN 2600 LIFTED OFF WITH AND STUCK TO THE COOLER ...while the retention arm was in the locked down position. This isnt the first time this has happened
           when i was a kid it happened to me while repairing my old computer.
so it took a lot of concentration to unstick the cpu from the bottom of the heatsink.
then after 6 or 7 attempts of reseating the cooler it finally screwed in.\
my power supply is being delivered tomorrow so ill have to test it out then but my temps are gonna be so high lol. We'll see though..i wanted to aftermarket cool it anyways.
that is something that happens with PGA chips. Just have to be careful.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
you're supposed to give the cooler a twist and perhaps slide it off as room provides. If your system wasn't run you may be ok, and if you don't fully tighten the cooler you can remove it to check your spread without stressing about reapplying paste, if you fully tightened it you could use a scraper to glob the paste up so it can respread, again as long as the system hasn't been run.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
