Is my power supply enough?
7 minutes ago, kitsuneshrine said:US
Ah, easy. Plenty available. All have links to PCPP, then you can see what price that are at different stores and click on the store to be taken to the stores website for the item.
Absolute cheapest that you could go
Corsair CX550 (2017)
CoolerMaster Masterwatt 550
Acceptable
Bitfenix Formula 550W
Be Quiet Pure Power 11 500W
Preferred
Corsair RM550x (2018)
Bitfenix Whisper M 550W
If you're looking at a high end card like the RTX2080, you can probably afford to go beyond the cheaper stuff. Out of those I would personally preference the Bitfenix Whisper 550W.
3 minutes ago, kitsuneshrine said:Would the ASUS - ROG Strix B450-F Gaming (Socket AM4) USB 3.1 Gen 2 AMD Motherboard with LED Lighting be good with the parts im going to get
IMO the Asus Strix B450 boards are a little overpriced for what they are. Not bad, but usually equal or better stuff from other manufacturers for cheaper. I would definitely consider keeping the CPU & motherboard you have and look at the other upgrades first, and then maybe consider a new CPU & motherboard when the new Ryzen CPUs launch in a few months along with new motherboard chipsets... Though the Ryzen 2700 is still a good CPU and the B350 Bazooka will be fine if you're not overclocking, so consider CPU&Motherboard replacement low on your list of priorities.
