My macbook air 2014 keeps on getting close to 100C (i use macs fan control, but just to monitor the temperature), when like using imovie and stuff like that
will replacing the thermal paste make it better?
or is it just the mac's processor is trash?
do macbook airs even have thermal paste?
https://linustechtips.com/topic/1053686-replace-thermal-paste-on-macbook-air/
nah mate just throw the entire interior, keyboard and hell why not the entire fucking thing and get it replaced for three times what you paid for it originally! :)
Builds:
2 minutes ago, noobofepicness66 said:
so, i should replace the thermal paste?
and it's worth it?
No, it wouldn't be worth it to replace the thermal paste, it wouldn't give much of a boost in performance..
There isn't much you can do to fix it.
If my answer got you to your solution make sure to 'Mark Resolved!
( / . _ . / )
  • 1 month later...
Ignore the elitists and go for it, it's a relatively simple and safe fix if you're careful. I recently did some maintenance on my friend's 2012 macbook air, and temps dropped by about 20 °C. Pretty much any thermal paste should do, temp delta by using the highest quality thermal pastes is pretty minimal. Just don't use some shitty chinese OEM paste and you'll probably be okay for several years.
Read up on some guides or watch a tutorial before you start opening it up and take your time, while following the guide. You will need a special pentalobe screwdriver for the case, because apple hates consumers. Be sure to also clean lint and dust out of the fans while you're inside the machine, that will help bring your temps back down. Just remember to take your time and not to misplace any parts or screws.
Good luck with your repairs
