Using pip in cmd and installing tensorflow (python)
Two questions here regarding installing modules and using python in command prompt.
I've linked up python to cmd, so when I type in python, it lets me do python code in the cmd module. I thought after that, all you'd have to do is import pip, then type -m pip install <module>, however, I keep running into the error "pip" is invalid syntax. I'm able to get modules to install with pip just fine if I create a cmd with "pip install redis," but I just can't get it to work through cmd. What am I forgetting?
The other question was regarding the tensorflow install. I took a look at their website, but I must have forgotten something? Again, I tried to use pip ("pip install tensorflow" as well as "pip --upgrade tensorflow") with a cmd file. It runs but some error pops up. I can't really tell you what the error is because the cmd prompt closes instantly after the error, but I'm sure it's probably because I'm forgetting something.
Thanks.
You need to run this from the command line:
python -m pip install redis
Or:
pip install redis
Also, don't store your commands in a bash file but just open command prompt and manually enter and execute them (then it will show you the error without immediately closing).
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
Or:
pip install redis
Again, it just keeps giving me a syntax error with install. You're right, I really shouldn't be using the bash files, but I just haven't been able to get the pip cmd lines working properly.
edit* I should note that the previous statement "python -m pip install redis" does work. Not sure why I can't use "pip install"
I’m not sure how you installed python & pip but it seems like pip is not in your path.
Ensure that the Python scripts folder is in your path (https://projects.raspberrypi.org/en/projects/using-pip-on-windows)
Alternatively, just reinstall Python and make sure to check the “set PATH for all users” checkbox.
The reason it's not working is that you're trying to do "pip install redis" inside the Python-interpreter. That's not how you do it. "pip install redis" is typed into cmd itself, not inside the Python-interpreter. You literally do win+r, type cmd followed by enter, then type pip install redis into it.
This. Ideally you should be using python venv to build a local environment rather than using your global environment
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Idk, maybe something isn't right like you said. I don't remember if I checked off set PATH for all users (I would have assumed I did) but it's possible I didn't.
If I were to type pip install redis directly into cmd, it will say "pip is not a recognized command." Again, it is possible because the PATH isn't correctly configured.
I will give a look into venv in the future. Just curious, why is it better to create a venv than using cmd to install modules?
UPDATE: I just reinstalled/ modified python and "pip install <package>" is now working fine in the cmd. Thanks for the help.
