Yesterday, I accidentally deleted the wrong partition and needed to recover all the files from it. As a follow-up to this post, I'm making a new post, as the circumstances have changed. Here's what happened:
  1. Accidentally deleted the wrong partition;
  2. Tried recovering the partition using Partition Wizard, EaseUS, etc.;
  3. Was finally able to recover most of the partition (3GB were left out, for some reason);
  4. Now, the recovered partition shows up as RAW and can't view any files;
  5. All file recovery software I've tried either shows nothing found or a bunch of .SWF files, which are Adobe ShockWave files, which I didn't have;
  6. I'm screwed;
I had irreplaceable data in that partition and I absolutely need to recover it. I'll take any suggestions. Please read the post linked above to see the different suggestions I got, as I tried them all already.
Many thanks,
Bruno.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/1049213-need-help-recovering-critical-data/
-Moved to Storage Devices-
As much as I like & prefer DIY if you've already tried a series of your own recovery softwares with no luck and this data is SERIOUSLY irreplaceable it may be time to consider professional recovery.
There's also the concern that you probably haven't set the drive to read only mode meaning there may already be data that you won't be getting back as it stands right now.
I'm trying to remember the name of the company LMG used to recover their SSD server data a couple years back.
In the future proper up-to-date backups are very important for situations such as this.
I decided to go with a Data Recovery company, as I have no other option. Tried every data recovery trial out there and still wasn't able to recover the files, which also kills the hope of a company recovering my files, since they use software anyway.
