Hello everybody!
I am looking to get a third monitor soon, but since my desk is too small for me to have all three (27'') monitors and my PC case, I want to wall mount my PC.
I've found the Thermaltake P-Series, which is looking promising (yes I know dust will be a problem, since it's open), but I want to see if there are any alternatives, so any recommendations are welcome!
It should support:
- ATX motherboards (duh)
- ATX PSUs (duh)
- 3+ 2.5'' drives
- vertical mountable GPUs and tempered glass are welcome, but not neccesary
Thank you in advance!
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/1049157-wall-mountable-pc-cases/
3 minutes ago, myselfolli said:
Also, if anybody has any recommendations on how to hide the cables comming down from the PC - also very much welcome
cut a hole in you wall and shove a piece of  cable conduit down add a couple covers. Just like you would do for a wall mounted TV https://www.amazon.com/Datacomm-50-3332-WH-KIT-Panel-Cable-Organizer/dp/B001PB75U6?ref_=fsclp_pl_dp_7
https://www.platt.com/platt-electric-supply/Flexible-Conduit-Innerduct-Residential/Carlon/SCH4X1C-50/product.aspx?zpid=522400
also as far a wall mount cases go Besides the Thermaltake  P series your kinda out of luck the only other option I see is like an inWin D frame and mounting it with C clamps. But most of the wall mount options are custom made.
Thermaltake Core G3
If you can find a Lian LI PC-O7S, for a reasonable price (no longer made)
On 3/28/2019 at 9:15 PM, TVwazhere said:
Thermaltake Core G3
Sorry for the late reply.
I'll definitely look into the Core and Lian Li cases. Drilling a hole into my wall to route some cables isn't an option sadly...
