Posted March 26, 2019 I find out my gtx970 msi gaming goes over 85C, I will see artifacts. Only some games go up to 85C (eg yakuza/ FF XV will) and gpu is always above 99%load, coz mostly on ultra graphics . But when I want to stress test to fine tune my overclocks, Temps couldnt reach over 80C on furmark & heaven or both stressing together. My cuurent settings: Voltage stock. power/temp limit +10/93C core +104mhz (gpu has min increment of 13mhz) mem+450mhz How do you test for max temp Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2019 12 minutes ago, dgsddfgdfhgs said: I find out my gtx970 msi gaming goes over 85C, I will see artifacts. Only some games go up to 85C (eg yakuza/ FF XV will) and gpu is always above 99%load, coz mostly on ultra graphics . But when I want to stress test to fine tune my overclocks, Temps couldnt reach over 80C on furmark & heaven or both stressing together. My cuurent settings: Voltage stock. power/temp limit +10/93C core +104mhz (gpu has min increment of 13mhz) mem+450mhz How do you test for max temp I would trry using the MSI Kombustor idk tbh Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2019 Author 7 minutes ago, Greenish said: MSI Kombustor totally forgot that one, thx Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2019 19 hours ago, dgsddfgdfhgs said: I find out my gtx970 msi gaming goes over 85C, I will see artifacts. Only some games go up to 85C (eg yakuza/ FF XV will) and gpu is always above 99%load, coz mostly on ultra graphics . But when I want to stress test to fine tune my overclocks, Temps couldnt reach over 80C on furmark & heaven or both stressing together. My cuurent settings: Voltage stock. power/temp limit +10/93C core +104mhz (gpu has min increment of 13mhz) mem+450mhz How do you test for max temp Here's a question nobody's asking: is it worth it? Why do you need to test max temp? If it's not going over 85 in games don't sweat it. If you want to test overclock do it in actual games you play. Main System: EVGA GTX 1080 SC, i7 8700, 16GB DDR4 Corsair LPX 3000mhz CL15, Asus Z370 Prime A, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R5, 2TB Seagate Barracuda, 500gb Samsung 850 Evo Secondary System: EVGA GTX 780ti SC, i5 3570k @ 4.5ghz, 16gb DDR3 1600mhz, MSI Z77 G43, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R4, 3TB WD Caviar Blue, 250gb Samsung 850 Evo Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
