1 minute ago, AskingForAFriend said:
If I format the HDD inside the PS4 on a PC and try to reinstall the software to 5.05 can I? Or are Sony assholes and won't let you? I wanna jailbreak the console, if you're wondering.
No, that won't downgrade the firmware as some of the firmware has already been written to the internal NAND-flash. Sony doesn't want people downgrading the consoles exactly because that'd make it easier to jailbreak them.
https://linustechtips.com/topic/1047786-downgrade-ps4-firmware/#findComment-12422060
shit. I thought that as well
https://linustechtips.com/topic/1047786-downgrade-ps4-firmware/#findComment-12422196
no, its locked.
Sony thought about that.
So you need to get an older PS4 (PRO) with hackable firmware.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1047786-downgrade-ps4-firmware/#findComment-12422208
