Replacement 4pin cpu female connector
Series is Molex Mini-Fit Jr. 4.2mm (0.165")
These are the connectors on cables:
Circuits | V2 Natural | V0 Black | V2 Yellow | V2 Black | V0 GW Black | V0 Natural |
24 | 39-01-2240 | 39-03-9242 | 39-02-8241 | 39-01-3245 | 50-36-1667 | 39-01-2245 |
20 | 39-01-2200 | 39-03-9202 | 39-02-8201 | 39-01-3205 | 39-01-2205 | |
8 | 39-01-2080 | 39-03-9082 | 39-02-8081 | 39-01-3085 | 50-36-1713 | 39-01-2085 |
HX6 | 39-01-2060 | 39-03-9062 | 39-02-8061 | 39-01-3065 | 50-36-1672 | 39-01-2065 |
4 | 39-01-2040 | 39-03-9042 | 39-02-8041 | 39-01-3045 | 50-30-4461 | 39-01-2045 |
HX5 | 39-01-4050 | 50-30-4447 | 39-01-4051 |
Amp/Tyco VAL-U-LOK series (mini-fit jr. clone / alternative)
Circuits | V2 Natural | V2 Black | V2 Red | V2 Blue | V0 Natural | V0 Black | V0 Red | V0 Blue |
24 | 2-794954-4 | 2-1586075-4 | 2-2029091-4 | 2-2029097-4 | 2-1586019-4 | 2-2029029-4 | 2-2029094-4 | 2-2029100-4 |
20 | 2-794954-0 | 2-1586075-0 | 2-2029091-0 | 2-2029097-0 | 2-1586019-0 | 2-2029029-0 | 2-2029094-0 | 2-2029100-0 |
8 | 794954-8 | 1586075-8 | 2029091-8 | 2029097-8 | 1586019-8 | 2029029-8 | 2029094-8 | 2029100-8 |
HX6 | 794954-6 | 1586075-6 | 2029091-6 | 2029097-6 | 1586019-6 | 2029029-6 | 2029094-6 | 2029100-6 |
4 | 794954-4 | 1586075-4 | 2029091-4 | 1586019-4 | 2029029-4 | 2029094-4 | ||
HX5 | 1586026-5 | 1586027-5 |
WST (Weli Sheng Terminal)
Circuits | V2 Natural | V0 Black | V0 Yellow | V0 Red | V0 Blue | V0 Green | V2 Black |
24 | P24-I42002 | P24-I42002Z-B | P24-I42002Z-YE | P24-I42002Z-RE | P24-I42002Z-BL | P24-I42002Z-GR | P24-I42002B |
20 | P20-I42002 | P20-I42002Z-B | P20-I42002Z-YE | P20-I42002Z-RE | P20-I42002Z-BL | P20-I42002Z-GR | P20-I42002B |
8 | P8-I42002 | P8-I42002Z-B | P8-I42002Z-YE | P8-I42002Z-RE | P8-I42002Z-BL | P8-I42002Z-GR | P8-I42002B |
4 | P4-I42002 | P4-I42002Z-B | P4-I42002Z-YE | P4-I42002Z-RE | P4-I42002Z-BL | P4-I42002Z-GR | P4-I42002B |
EPS12v Connector:
Mini-Fit JR ; 5557
Circuits: 8
Part #: 0050361713
Sex: Male
Mate: 5559
Crimp Terminal #: 0039000039
4-pin CPU power.(Replaced by EPS12V)
Series: 5557
Circuits: 4
Part: 0050361746
Sex: Female
Mate: 5559
Digikey codes for housings made by Amp/Tyco (Molex Mini-Fit compatible) :
4-pin power supply housing for male pins A1402-ND
4-pin power supply housing for female pins A1431-ND
8-Pin EPS +12 Volt
3.7.1 Molex
- 39-28-1083 - Male, PCB Header, V2, Natural (White)
- 39-01-2080 - Female, Crimp Housing, V2, Natural (White)
- 39-01-2085 - Female, Crimp Housing, V0, Ivory
- 39-01-3085 - Female, Crimp Housing, V2, Black
- 50-36-1713 - Female, Crimp Housing, V0, Black
3.7.2 AMP/TE
- 2029091-8 - Female, Crimp Housing, V2, Red
- 2029094-8 - Female, Crimp Housing, V0, Red
- 2029097-8 - Female, Crimp Housing, V2, Blue
- 2029100-8 - Female, Crimp Housing, V0, Blue
So basically, go to a distributor like Farnell http://uk.farnell.com or http://www.digikey.com or http://mouser.com or http://www.rs-components.com
For example, Digikey > connectors > rectangular connectors - housings > molex > mini-fit jr 5557 : Digikey link
And if you look in the first table, one of the first results should be the 4pin molex 0039039042 : https://www.digikey.com/product-detail/en/molex/0039039042/WM13116-ND/4693015
And you can see in the tables above, vertical headers : 5566 series would be one.
I went with molex , 4.2mm pitch, 4 positions in the rectangural connectors - headers - male pins and got this: DIGIKEY link
A bunch of the first results are these - just have to pay attention at the keying inside (look in datasheet and see how the plastic is actually keyed and make sure your 4pin eps goes inside):
1 https://www.digikey.com/product-detail/en/molex/0039281043/WM3801-ND/61400
2 https://www.digikey.com/product-detail/en/molex/0039288040/WM23801-ND/930297
https://www.digikey.com/product-detail/en/molex/0039299042/WM7325-ND/1624281
https://www.digikey.com/product-detail/en/molex/0039293046/WM3844-ND/2002651
https://www.digikey.com/product-detail/en/molex/39-29-9043/WM3854-ND/2002661
https://www.digikey.com/product-detail/en/molex/0039306047/WM17746-ND/1633818
Though usually the ones stocked in higher quantity are the most common used.
