Is it okay to delete and repost for help?
The current ruleset has been shrunk down as compared to the old rules. In the past it said you could bump your post every 24 hours (that means, you can post in your own thread with some more info or not to 'bump' it up in the sub forum) and it said reposting was not allowed.
The part of the community standards you're quoting has to do with backseat moderating.
'Normal users', like you, I and the majority of the users can't just go around acting like moderators, that is the moderators jobs. So instead saying "you did X wrong" or "what you did is against rule Y", you're suppose to just report a user's post and let the staff here deal with it.
But anyways, my personal opinion on reposting is that you shouldn't do it, but if you have a ton more relevant info you should be allowed to. A blind copypasta repost should not be allowed, but a 'bump' with the extra info is usually the most elegant solution.
Of course I say this from a regular user standpoint; I cannot speak on behalf of the rules.
