Hi guys, back again for some more info, as you seem to be the most knowledgeable forum on the webs!
So I have an old netbook with an atom n270 (I think). Either way it's a 32-bit chip with legacy bios only. Got 3 OS's on it (2 Linux and windows 10 for if I need it) but I had to use an extended partition for the 3rd. Was doing some research into MBR and GPT.
So my question is, do you reckon I could boot using GPT (I know windows wouldn't boot from it, but I'm getting a decent laptop soon so that doesn't matter to me) on a 32-bit legacy system, I know 32-bit isn't an issue but does GPT require a UEFI system? The only info I can find is for 32-bit UEFI systems so am a bit stuck.
TIA!
https://linustechtips.com/topic/1046547-gpt-on-32-bit/
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
https://linustechtips.com/topic/1046547-gpt-on-32-bit/#findComment-12411347
8 minutes ago, D-J97 said:
It a great little web browsing machine, good enough for what I needed at the time
It isn't a great web browsing machine nowadays. Seriously, it's hell, even on very lightweight browsers and distros.
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1046547-gpt-on-32-bit/#findComment-12411495
OP is happy with it, why are you arguing?
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/1046547-gpt-on-32-bit/#findComment-12411497
I've used a Atom N280 for about a week before, during february this year
On Lubuntu, it would hardcrash the system at any more than two tabs because of the CPU, and every webpage loaded like you were on dialup (on a 100mbps connection).
https://linustechtips.com/topic/1046547-gpt-on-32-bit/#findComment-12411503
I upgraded it to 1.5gb ram which is the max for this one, but it still doesn't like loads of tabs, think I've had 5 open before in windows, don't know in Linux but I run arch with i3 to save all the ram I can, the resolution is probably the biggest issue
https://linustechtips.com/topic/1046547-gpt-on-32-bit/#findComment-12411544
Makes sense then, I had the N280 with 1GB and the RAM was a limiting factor too
https://linustechtips.com/topic/1046547-gpt-on-32-bit/#findComment-12411580
Only an extra 60khz over mine, basically the same chip, I was looking into setfsb, but not going to take it back apart to find the clock generator number when I have the Omen coming
https://linustechtips.com/topic/1046547-gpt-on-32-bit/#findComment-12411663
