Can top exhaust fans "steal" air from heatsink fans and rear exhaust fans?
Okay, here's a quick and dirty sketch of what your airflow will probably look like with the 200mm.
Air gets sucked in through the front 200mm fans. Some of the air is sucked straight out by the 200mm in the top, the rest goes to the CPU cooler and GPU cooler.
Once air passes through the CPU cooler, it'll go straight to the rear fan.
The air from the bottom 200mm intake will mostly go to the area below the GPU. Once it passes through the GPU, it will radiate upwards and be sucked out by the 200mm in top and the 140mm in the rear. Note that most of this hot air from the GPU goes over and under the CPU cooler, not through it. A small amount will enter the CPU cooler indeed, but that cooler has its own airflow going on thanks to its fan, so the air from the GPU that enters the CPU cooler will be blown towards the rear straight away.
The big question is if the pattern will be better with a 140mm at the back.
Personally I don't think so. In terms of position it will be better, but the 200mm simply moves a lot more air at a low RPM than a 140mm would. That more than makes up for the bit of air (the top 2 blue lines)that gets lost.
All in all, my advice would be to not overthink it. Regardless of what setup you choose, you won't run any risk of overheating things due to bad airflow.
You can always mess around with fan curves once you have the PC up and running. Perhaps lowering or raising the RPM of the top fan compared to the rear one can drop the temperature by a couple of degrees.
