I've built a lot of PC's. This is my first Ryzen build.
My client's old LGA1150 i5 build was killed by a power surge, He wanted something cheap as a replacement, and thus switched to AMD for his gaming.
I built the system for him.
It has an MSI A320M PRO-M2 V2 motherboard (Bios unflashable because MSI apparently does this really cheap "Retail BIOS flashing not permitted" thing... Would've solved all my problems by now).
It has 8GB HyperX 3200MHz RAM,
Ryzen 3 2200G,
And a Galax GTX 960 EXOC.
I've installed the GPU drivers probably around 4 or 5 times now by this point [uninstalled them prior by using DDU]
I've installed the chipset drivers several times too in trying to fix this.
The GPU outputs to 2 monitors. 1 over DVI (to VGA adapter), and the other over HDMI.
For the past week the HDMI just gave up. Its not the cable, as that works with any other device you plug into it.
Its also not the GPU driver, because i've reinstalled that several times.
Windows does not even detect the HDMI monitor when its plugged in.
IGPU Multi-monitor is not an option on this board, so plugging it into the mobo wont help.
I've worked on, serviced, and built a few hundred PC's (I was a tech in a local PC Shop back in the Windows 10 upgrade period), but never has a brand new PC given me as many problems as this build.
If you can figure this out, You'll be God himself.
[tl;dr] I'm at wits end, and angry at computers. F'ing Ryzen...
https://linustechtips.com/topic/1045834-so-many-problems-first-ryzen-build/
Did you test if the GTX 960's HDMI port died?  Try the card in a known-good system?  May just need to try a different GPU in the system.
That'd be my go-to considering it's just a video problem and I don't see how that's a Ryzen CPUs fault (since you're not using the iGPU anyway).
2 minutes ago, Neftex said:
how did you come up with the conclusion its the CPU fault is beyond me
Yesterday my client messaged me to tell me that the board suddenly lost internet connectivity, and HDMI signal to the monitor. Only picking up the DVI monitor. He went to device manager to find 6 devices showing as having driver issues.
1511317284_WhatsAppImage2019-03-18at18_20_42.thumb.jpeg.2b6dd1eebd8b798592b9fc1ccec18117.jpeg
Now i have never heard of one GPU port dieing and taking down a bunch of mobo devices with it and then coming back to full functionality a few hours later, And that is how i came to the conclusion it was the CPU/Mobo combo.
i assume you're using the previous graphic card so wehen there is a Power surge there is a high chance that hdmi port on the graphic card must have died
Have you tried plug in to the on board hdmi port just to check this will simply give ans about where the problem is
Cable, graphics card
If it works fine  its problem bwith Ur graphic card
One more point did u check monitor with other source it will also help you locate problem
There is a good chance for mobo problem too
A320 is total garbage when it comes to gaming. You want a B350 at a minimum. Last I heard, those MSI boards were among the worst of the A320 boards; could be the source of your problems.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
It's probably the motherboard. Ryzen is really wonderful, sucks that he's having issues.
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
the MSI B350 is literal garbage
id get the b450
id get the b450
lol, unsurprising. But I never strictly recommended the MSI one, I've been running an Asus Strix B350-F on my 2600x and its been good to me.
*GPU Test Bench*
We tried the same monitor that isnt being detected by the GPU on his laptop which worked fine, using the same HDMI cable
id get the b450
From what I could find, It was the cheapest option, and the only option he could afford ?
What about the ASROCK B450M-HDV R4.0? 59$
You could try to RMA the board and hope the replacement isn't faulty, otherwise you'd be better off trying a totally different board.
*GPU Test Bench*
I'll have him test the GPU in a different mobo and plug HDMI into there to test, If still the same result I'll try and get out to him with my personal rig's 970 to test that. Guess there's another callout ?
He got hit with another power surge he just wants to blame it on you instead of buying another pc
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
It's not "fucking ryzen" because the problem is clearly a faulty motherboard, not the 960, not the monitor.
faulty PCI slots
no internet
unable to flash
everything points to it.
id get the b450
if it's from MSI it'll be the same as the 350, MSI fucked up and starting making garbage a long time ago when all this shitty RGB and "gamers" trend started and they starting bloating the boards with crap unless on focusing on performance
I'd go for ASUS and forget about it.
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
Hehe, He's a personal friend of mine too. I doubt that is his intentions, as he is aware I am in the rat-race too and cant afford to buy him new parts ? We installed a surge protector on the outlets that his electronics are connected to after the first surge fried the first board. They're only rated for so much of a surge though, and they happen constantly here because of rolling blackouts
I remember reading somewhere that the surge protectors aren't very useful at protecting against large surges (lightning strike, blackouts, etc.), and a higher quality power supply protects against the type of surges surge protectors protect against better anyway.
But I could be wrong. This story for me is on the same level of that time cousin Joe told me about his vasectomy. Filled with regret.
faulty PCI slots
no internet
unable to flash
The inability to flash is because of a retail bios being installed from factory, which they simply out right refuse to even go anywhere near (https://forum-en.msi.com/index.php?topic=290677.0) I agree with you on MSI being trash. I run an ASUS board on both my personal rigs and haven't had issues.
I would invest in an UPS then.
A320 boards are meant for business use, doesn't really surprise me they would install a retail BIOS.
*GPU Test Bench*
What would be the recommended chipset on a budget-AM4 socket board for gaming? You and @NunoLava1998 both mention the B450 boards. I've let my client know to test the card, and RMA the board if the card is good.
MSI claims that it isnt their OEM boards with the retail BIOS's on them, but rather boards made and sold to order to specific big-name vendors.
Could this mean that the vendor i bought it from (Or even their supplier), is selling these to-order boards with the retail firmware on?
I do not trust this vendor as far as i can throw them (They're pretty big here, and i even bought my personal rig from them 5 years ago, But since then they've gotten scummy with their marketing and pricing tactics.)
B450 is the best gaming board for anything below a 2700, x470 otherwise
For OCing on B450, get the GAMING PRO CARBON, TOMAHAWK or MORTAR only if above ryzen 5 1400
I've been looking into this for my own setup here, Both for the switches, routers, nas, and the PC's. At the rate these rolling blackouts are happening though, (2-3 times per/day for 2 and a half hours at a time [4 hours at a time in the cities]) it may even be more advantageous to invest in an Inverter/Solar package ?
My test bench's PSU is a victim of this electrical-outrage too. The list of casualties gets longer.
Edited by Flashie
Inverter not inventer
you're not supposed to "update" A320s tho that's why that option is locked.
About the outages and surges same happens to me and I had to go for an UPS and some protectors of my own design (I'm on 3rd year of EE) for the computers
also a diesel generator since outages usually last for days (or more)
I looked up solar kits and here it costs both kidneys and outputs little power compared to fuel not to mention the space it takes to install and that it depends on the sun of course.
