Hi Everyone,
I saw the video for the Sentry pc case, but even if we forget the fact that its still in crowdfunding phase, it will be pretty expensive.
Would anyone have any suggestions for something with a similar form factor that can take a full size gpu and with decent airflow ideally under €100 (which I think currently is around $115)  but the cheaper the better, more money for the gpu :). I like that form factor as it can easily fit in any cabinet, but I'm willing to consider anything that decently small
https://linustechtips.com/topic/1044643-itx-case/
@fasauceome will also recommend the SG13B because SG13B. Volume wise it's similar to node 202 and ML08 (there's also the RVZ series form silverstone), but it's not as easy to fit into a back pack if that's the sort of thing you're looking for.
https://linustechtips.com/topic/1044643-itx-case/#findComment-12394817
Thanks
37 minutes ago, SkyHound0202 said:
SilverStone ML08 or Fractal Design Node 202.
I really like the node 202, its exactly the look I'm going for
@TVwazhere not really, I just like the aesthetic of it looking like a vcr in the living room, which is where I will use it, right now the Node 202 is the one that I like most
https://linustechtips.com/topic/1044643-itx-case/#findComment-12394868
Definitely nice cases. I was toying with the idea of building an ITX machine once Ryzen3000 is out. My choice would have been Silverstone RVZ-series range, but these mentioned ML08 or FD Node202 is gorgeous. Thanks for the responses
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1044643-itx-case/#findComment-12395054
Well the Sugo is actually nice and thicc because the GPU is 90 degrees from the motherboard, as opposed to the node where it's parallel.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1044643-itx-case/#findComment-12395173
