Need help choosing the right 1660TI
7 minutes ago, FMoh said:Thankyou for your response! i am having trouble finding an EVGA 1600TI on the market with a double fan let alone 3 fans?! are you able to assist in where i can get one from? I am in the UK
The single fan triple slot card is pretty good, you don't need to get the dual fan one. I don't believe they make a triple fan.
The dual fan and single fan EVGA XC Black 1660Ti should have near identical temps. The dual fan is longer and has a thinner heatsink, with 2 fans to help. The single fan is shorter with a thicker heatsink, and has a larger and higher rpm fan to cool it.
During my testing, before handing the system off to my friend, the GPU never exceeded 65C; even in Time Spy extreme and Superposition 1080 Extreme.
Here's the system, for reference:
Ryzen 5 2600 @ stock speeds and stock cooler
Asus TUF B450M
16GB (2x8) 3000Mhz G.Skill Aegis DDR4
250GB Inland SSD
1TB HDD
EVGA XC Black 1660Ti (triple slot)
Fractal Design Focus G (stock fans left in, added 4 Arctic F12 PWM PST in remaining slots)
BitFenix Formula 550W 80+ Gold
2 minutes ago, FMoh said:Thankyou for your reply! So if im going for a 1660ti get the cheapest on the market but if i spend a little more get a 2060. Do they have a 2060 with an RGB interface and if so what would you recommend?
Usually, only the high end cards (1070 and above, for last gen) have actual RGB connectors on them for case LEDs. Lower end GPUs can still have RGB built into the GPU shroud, but won't have additional headers. If there is a 2060 with RGB headers, I would suspect that it would be an Asus Strix model (my 1070 Strix had an RGB header for connecting LED strips to).
