so aside from my main build, i have a secondary build in mind, which as i posted in the liquid cooling section, based off Command & Conquer, Brotherhood of Nod. i'm making a mockup on pcpartpicker, and stuck on deciding which case. mainly because i just can't pick anything that's perfect. call it being stingy if you want
my 2 main choices are stuck between either the Corsair Spec Alpha to which i absolutely love the front panel, but the side panel has the small window design
the other choice being the Phanteks Eclipse which suits my internals perfectly, having fittings for water cooling and reservoir, but the front panel is just bland to me.
i also came across the Azza Inferno 310 which looks like a great compromise, except the internals on the main website don't seem to show any reservoir fittings, just that it supports a radiator on the top
case pic
so i'm open to ideas of anything that may suit my needs, or advice on which of these i should go for
https://linustechtips.com/topic/1043625-help-in-deciding-a-case/
I personally love fractal design stuff, even their cheaper focus G line stuff is very nice for $50.
I may use a meshify in white on the next personal build for myself.......
The last 2 builds ive done for friends both used the focus G and for the money it was an awesome case.
2 minutes ago, zeromaveric said:
the omega's front panel is less in showmanship to the alpha, in my taste. and while the Meshify S2 does look really good, i'm pretty much going by a theme of red and black for color, which really limits my options.
You can always get a black case, rgb or red cooling fans, and then a nice window with red and  black internal parts.
~$50-100
Corsair SPEC-04
Coolermaster MB510LMB511
Focus G
Silverstone RL06
>$100USD
Riotoro cr1088
NZXT H700
Corsair 570X
Coolermaster MC500Mt
