Hey guys its Robert and I am a pc enthusiast but ive always had one question i cant find much info on. Can I upgrade from a 32 bit processor to a 64 bit without changing anything else? If not what do i need to change. Also im looking to install a good graphics card in a friends optiplex 780.(Its a small form factor) Will a Geforce gt 730 fit?
https://linustechtips.com/topic/1042584-need-some-help/
No, you'll need to reinstall Windows. Also, whether your mobo supports a 64-bit CPU or not depends on your mobo, obviously.
https://linustechtips.com/topic/1042584-need-some-help/#findComment-12376361
Huh? The last 32-bit mainstream processors from Intel were the Pentium 4 series back in 2001. If you indeed mean the processor (rather than the operating system), swallow a pill and look at building a new system as everything you have will be out of date (and probably well past its use by)..
https://linustechtips.com/topic/1042584-need-some-help/#findComment-12376390
As for the OS, it is best practice to perform a clean install of windows when moving to a new machine, even if moving from one 32-bit platform to another.
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
https://linustechtips.com/topic/1042584-need-some-help/#findComment-12376442
