Lil help bout breaking a monitor
Just make sure that whatever cable is connected between the monitor and the computer doesn't break inside the computer.
e.g. if you are using HDMI, the HDMI cable inside the computer may break off inside the computer with enough force.
It won't do anything to your computer, but you won't be able to use that port anymore.
Featured Topics
INotPablo ·
nugget1414 ·
Posted in General Discussion0 -
KN923 ·
Posted in Troubleshooting0 -
Subrand0m ·
Posted in Networking0 -
TIMEK33PER ·
Posted in Troubleshooting1 -
Denny M ·
Posted in New Builds and Planning1 -
Theminecraftaddict555 ·
Posted in Audio0 -
