I dont know how it happend but now whenever i play minecraft and denstiny 2, the fps gets locked at 75fps (got 75hz screen) even tho i have disabled vsync in both the nvidia control panel and in game. It isnt super bad but i would like to have some more fps than 75 so i dont notice if the fps drops some. I remember something about 2 vsync options in the nvidia control panel but i cant remember where and if im right. And i dont think its my pc that cant get more than 75fps either since it should be able to play those games easily.
I havent noticed this problem in other games like in cs go, cause on there i get over 200fps and it doesnt seem locked. I dont know what have happend but i really want it fixed as fast as possible.
SPECS:
ryzen 3 2200g (stock)
asrock a320m-hdv r3.0
8gb 2400mhz (stock)
Asus Cerberus 1050ti (OC version + my own OC, just a bit)
https://linustechtips.com/topic/1041523-fps-locked-with-no-vsync-help/
Just now, DankDeuxez said:
well from what know ive already disabled every fps lock/vsync thing i can find in minecraft and destiny 2
do you know if either game it using both cpu and gpu to their full potential? or even your ram? I use HWinfo64 to monitor all my stuff.image.thumb.png.4781df09bc911f152b04873af98cef66.png
It should use my cpu and gpu to their full potentional, and i dont think there are any bottleneck since the ryzen 3 pairs super well with the 1050ti
the only thing I can thing of is those games need setting up correctly in the nvidia control panel, there's 2 settings, global and program specific.
the place where ive disabled vsync is in the "Manage 3D settings" tab
4 minutes ago, DankDeuxez said:
That did NOT fix anything.. The fps was still locked at 75...
Either you have something set to adaptive or gsync or something cos it shouldn't be limited to anything. I would deffo check to see if those 2 games in their settings have a priority set to match the refresh of your monitor.
well minecraft doesnt seem to have anything about fps have to match my screens hz and not destiny 2 either. i also tried to reset the settings in the nvidia control panel to see if it changed something. it didnt, so i changed to vsync off and it didnt change
3 minutes ago, Benjeh said:
Ok i need to see screenshots now cos I don't know what setting you have on what, have you set power management mode to max performance?
OpenGL rendering gpu to your gpu and not the apu?
i have set the power managment to max performance (in windows 10 settings), and i dont know how to check if i got the OpenGL to the gpu and not apu...
that will just affect CPU.
5 minutes ago, DankDeuxez said:
here is some of it
Power management mode - Optimal power -> Max performance.
changed to max performance but its still locked. my pc doesnt have problem running the game, its just that the fps is capped even to i dont have ANYTHING that tells it to cap
