Alot of people always say using old power supplys is a bad idea cuz it can blow up or damage components. But why would this be due to aging as far as i see the capacitors will get less capacitance and your output voltage would be less stable. But why would an old psu blow up if it isnt clogged with dust or anything?
https://linustechtips.com/topic/1041169-old-power-supplys/
Cheap/old components can fail, it is as simple as that. Even voltage ripple can kill components, regardless of whether or not the PSU itself does not fail. Also, voltage control is better on new PSU's.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12364146
I'm not sure why people assume that capacitors are the only thing in a PSU that fail.  But it's a common misconception.  A PSU is not a box full of caps.  Nor do capacitors in PSU tend to fail.
If the output caps fail and the ripple increases, that can kill components.  But failing rectification circuits, like from an overworked or overheated MOSFET, can cause a lot of damage if the PSU's protections don't kick in.  Or if the UVP is set to low or the OVP, OCP or OPP is set too high?  And what if the housekeeping IC isn't fully functioning?   You can hope for a complete failure, which would cause the PSU to not power on at all.  But that's not always the case. Some failures may only occur at higher temperatures.
This is a fun read:  https://anysilicon.com/best-practices-ic-troubleshooting-ic-failure-analysis/
Speaking of higher temperatures....
The part that typically fails first in a PSU is the fan.  This doesn't always cause a problem immediately, of course.  If you have a high efficiency, high capacity PSU, you may never experience a problem with the PSU running without active cooling.  Say you're using a 1000W Platinum PSU to power a system with a single graphics card that really only uses 550W at the most.  But if you're using a cheaper, lower efficiency PSU that only has just a little bit of overhead above the amount of power needed, lack of active cooling can result in catastrophic failure of other parts.  A "domino effect", so to speak.  Fan fails.... FETs fail....  ICs fail....  Voltages go haywire and kill your parts.
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12364233
Its a bit more complicated, here we have a couple of different things, for example:
  • newer, even really cheap PSU are better than the average 10 year old one. Back in the day, most PSU were crap by todays standards
  • Changing in power consumption! Not just move to 12V from 5V (was in the early 200s) but also the way the components consume power. In the last couple of years its changing more towards more peaking current because of Power Saving Mechanisms and the so called "Race to Idle" philosophy. for example when you move the mouse the CPU clocks at higher frequency and changes it constantly and sometimes you hear that in the PSU
  • Aging components, for example ripple going high, Protections failing, voltage regulation getting loose and other stuff.
The thing is that you do not know how good the PSU is and you don't have the gear how it looks.
An example of how older PSU might look is here (Sadly German):
TL;DR:
one of the PSU is around 500mV, the other PSU is around 1V or more
The Specification is around 120mV...
Modern PSU are under 60mV (cheaper ones) or the better ones are like half of that.
Voltage Regulation, the shitty ones are at 3% for 12V, the better ones at 1% or lower.
How can you say that???????
Everyone knows that only Capacitors fail!!!1111
Or just not there...
As some Protection Chips like the HY-510N I like to mention don't come with UVP on 12V at all and some/many have very low UVP trip points that are almost useless. IIRC some are at like 8,5V or so for 12V.
But but you can replace the fan!!11
That is easy!!1111
Here a "Guide": FROM 2014!
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12365112
6 hours ago, campy said:
But if you can find an S12II or something like that for dirt cheap, grab it, its gonna be a decent psu with a 5 year warranty. Just that its not preferable to modern power supplies under normal circumstances.
Why should he?!
For the amount of money those things are sold, you can get DC-DC units from some Companys.
ANd I rather have a (new) Corsair VS than S12II because its better.
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12365122
3 minutes ago, campy said:
VS series has only a 3 year warranty, lower efficiency,
Irrelevant measures.
3 Years or 5 years don't matter.
Efficiency doesn't matter
Voltage regulation does matter
Protection does matter
Theyre really just average PSUs but the S12II's are higher efficiency with a better warranty and about the same price on average.
The S12II is loud as hell, ~2000rpm at 250W load or so.
No Undervoltage on 12V
No overcurrent on any rail
Group regulated
Hence why i say "for dirt cheap" because something like the S12II 520 still goes for 50-60$ which is just too much for what it is, but ive seen em on sale often for 30-40, which is worth the 10 bucks over the VS 550 if it was off rebate.
No, it is not.
Why the heck do people still recommend the S12II when you can litterally get everywhere a better unit for the same amount of money or a better unit?!
Oh wait, you got blinded by Wapanese caps, made in China, wanna be Japanese...
The EVGA 500B being a similar older unit a little bit more on par with the S12II's
I'd say even the EVGA 500B is superior to the S12II...
Its like, yeah, the S12's are so old they dont even support the haswell power saving features,
...wich is why you do nor recommend it because it gets beaten the shit out of it by many lower end PSU from various manufacturers.
You even can get some DC-DC units from some manufacturers.
You can get somewhat decent protected PSU from manufacturers.
Here more information for you:
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12365194
2 minutes ago, jonnyGURU said:
Assuming you realize the fan actually died.
Sorry, forgot to mention that most of the post I quoted you was joking and not honest.
I'm not an advocate of replacing the fan for many reasons, including legal ones...
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12365203
41 minutes ago, campy said:
Id take a 30$ 520w S12II over an evga 500b/vs450/cx450m/any other 500w generic any day simply because of that 5 year warranty and the fact that theyre tried and true power supplies.
Ok, so what if it is "tried and true" aka more well known? What difference does that make?
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12365247
2 minutes ago, campy said:
VS series has only a 3 year warranty, lower efficiency, and is the same kind of later years FSP guts as every other 80+ white label psu out there.
What do you mean by this? The VS series has the same FSP guts?
They're not the same price though.
Corsair VS450 is currently $39 (without rebate!). It's $24 with the currently available $15 rebate.
Seasonic S12ii is currently $55. That's more than twice as expensive as the VS450 is with the rebate available. Even without the rebates the VS450 is still $16 cheaper. If you're talking about buying cheap, low range PSUs then $16 is a huge difference in price.
https://pcpartpicker.com/product/fZyFf7/seasonic-power-supply-s12ii520bronze
https://pcpartpicker.com/product/6rc48d/corsair-vs-450w-80-certified-atx-power-supply-cp-9020170-na
You're saying that the reason you would choose a S12ii over a Corsair CX450m is that the S12ii comes with a 5 year warranty? That doesn't make any sense since the CX450m has a 5 year warranty as well. Not that it really matters. Putting a X year warranty on a unit doesn't make it perform any more reliable than if it had a Y year warranty. Yes, better built PSUs will typically come with longer warranties, but having a longer warranty period doesn't make it a better unit. If Corsair came out tomorrow and said "Hey everyone, we've decided the VS450 has a 5 year warranty now. Anyone who already owns one will be automatically upgraded to the 5 year warranty period" does that make the PSU already sitting in peoples systems magically become better built or more reliable? Of course not.
11 minutes ago, campy said:
They also have a really good looking box, not many people care about that, but i like that the box looks nice.
I'll have to keep that in mind for the next time someone asks on the forums for help choosing a PSU that comes in a cardboard box with a nice looking picture on it and doesn't care about the unit inside the box.
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12365280
Not necesarily.
You can also build a cheap unit that fails regularly after 4 years and calculate with a 10% Failure rate over its lifetime and also formulate the Warranty Terms in a way that they can exclude most PSU.
As for the Warranty terms:
Some Manufacturers have a couple of things that allow them to reject the Warranty for certain reasons.
The most common one is the proof of purchase because some people throw it away or loose it and thus no warranty for them.
Another example is Mining exclusions, wich they could also claim.
And Enviromental Damages are also excluded. So if a manufacturer is a bit malicious they remove the coating inside the case where you do not see it (but they know what to look for) and look for rust. Since it is steel, it will rust. But with rust, they can claim enviromental damage.
And some Manufacturers (like EVGA) Even have a Smoker Rule!
So if you smoke in your PC room, that voids the Warranty.
https://linustechtips.com/topic/1041169-old-power-supplys/#findComment-12368373
