Is My Graphics Card Getting Enough Power?
avrona
So my PSU wasn't really built for 2 8 pin graphic cards like the 1080 Ti I have now. Probably because 2 8 pin cards didn't even exist when it was made. My PSU only comes with 1 8 pin, a 6+2. So instead I use an adaptor that converts 2 6 pins into 1 8 pin, so I use that for the other 8 pin slot. However, my PSU only has 1 6 pin, meaning I could one use up one of those 6 pin slots in that adaptor. Is that bad or is my graphics card ok? I've had it since October and had no issues thus far.
if your PSU is that old, you really should upgrade it. Its likely a ticking time bomb at this point being old enough like that. You can get decent cheap units like the 50$ range that will have the connections you need.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Even that's too much for me though. I don't have the money to even upgrade that.
Then it needs to be a priority to save up for it and replace it.
"Black Out"
That will still take months for me to upgrade though.
You can't afford a $70 PSU, but a 1080 Ti, that's cheap as chips
Shouldn't have bought a GTX 1080 Ti then if you can't afford what it requires to run.
If you force it to work off an unfit-able Power Supply there are great chances it will result in the loss of both hardware.
Personal Desktop":
Luna, the temporary Desktop:
I agree with @Skiiwee29, a PSU that old should be replaced sooner than later, it is probably on its last leg and may take some other components with it on it's way out...
75% of what I say is sarcastic
So is the rest probably
I didn't pay for the 1080 ti though.
What psu do you have? Molex to pcie connector adapters are available.
An XFX TS550 Bronze.
4 minutes ago, avrona said:
And XFX TS550 Bronze.
Well get a 2x molex --> pcie6 adapter to get that missing 6pin. But be sure to plug those molex connectors in properly as they are shit.
Do I need it though? I mean my card is doing fine with just 1 6 pin.
Why did you create the topic then?
Because deep down he knows this will happen soon or later:
Seriously, if you got a 1080 Ti for free at least invest on proper power feeding, losing the high end GPU in a few months to save 70ish dollars like stated ain't worth it.
Personal Desktop":
  Reveal hidden contents
No I created it because I wanted to know if there was some issue with my setup or not, as it's been running fine so far, even with GPU heavy tasks such as 4k gaming or mining. And again, I simply don't have the money for a new PSU.
1 minute ago, Etrecz said:
You do really need both cable slots to be filled. So 1 cable instead of 2 is not enough.
You risk overdrawing the PSU and damaging it. It can also cause other components to not get enough power or deal with erratic power from an overloaded PSU, so unrelated things may also start to act up. Better quality PSU's are probably going to be more robust than lower quality cheap OEM provided ones.
A video card or other component may say it needs a 550w power supply, and it probably does only when fully loaded. So you may not experience problems on power on, but only after playing a game or something else that stresses the GPU.
Specific symptoms include:
  • lockups
  • BSODs
  • graphical corruption
  • display goes black
Well I am using a 550w power supply which came in my pre-built, and I've been having no issues. Well apart from BSODs for a few days but that was from damaged Windows files. And sadly even if the risk is as bad as you say, I don't really have a way to solve it, as I don't have the money for a new PSU.
Better have a fire extinguisher nearby I guess
I'm assuming fixed income, like disability?  Maybe join a local PC forum or club and see if you can get a used PSU for super cheap.
Or get a PSU in the same fashion you got the 1080Ti?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
No nothing like that, I don't have fixed income or disability. Plus the odds of winning another giveaway are pretty slim.
So... you have a regular job then?
OnePlus:
Other Tech:
Why? Most 8pins only have one ground wire more and sense. On some(old) psu:s there can be only 2x 12V wires in a 6-pin.
Because that's why.
Also look at my signature
