Questions to long term H500 users
lagista
I am in the market to buy a new case, of which I've narrowed down to NZXT's H500 and Fractal Design's Meshify C.
I'd like to ask people who have been using NZXT's H500 regarding airflow and dust.
Negative air pressure builds dust in the case.
How fast does the dust buildup relative to your other cases experience?
Is it an issue I should be worried about?
How often do you clean the dust in your system?
For reference, I will be running Ryzen 5 2600, with Cryorig H7 and a GTX 1070ti Zotac.
Also, white H500 users, have your case experienced any form of yellowing?
Thanks!
dust builds up relative to how dusty your house is
Hate how people think the case pressure has anything to do with it
oh, i am referring to the dust buildup on the PC components vs on the dust filter.
Dust filters are relatively easier to clean, as compared to when the dust settles all over the MoBo, CPU cooler and ram etc right?
My question would be, how much faster does dust accumulate inside the PC, relative to a positive pressure case. Is that fair?
Like this person?
i5 8600 - RX580 - Fractal Nano S - 1080p 144Hz
