Hi i am a pc builder and technician and i take apart and build a lot of computers. Using a handheld screwdriver takes up a lot of my time and im looking for a thin handheld electric screwdriver that is small enough to get to hard to reach screws. the ideal shape is something like a dremmel.
Asus crosshair hero VI  Gtx 1080ti  Ryzen 1700 16gb 3200mhz trident z RGB ram custom watercooled loop
https://linustechtips.com/topic/1039929-small-handheld-electric-screwdriver/
This might be of interest if you want a Dremel - like tool, it seems that they are now making a compact screwdriver: https://www.dremel.com/en_US/products/-/show-product/tools/go-01
I believe this is available at Lowe's and Home Depot stores in the US, though I do not recall the sell price and have not tried one myself. Otherwise, DeWalt and Makita both make compact cordless screwdrivers of a similar design, though they will be more expensive than this one. Happy shopping!
ES120. Look it up on Amazon, eBay, Banggood or similar sites. It's gotten great reviews, it's small, the li-ion cell is easily replaceable, should you need to and so on. I recommend checking a review or two on Youtube, if you're interested.
