I have been considering changing case and doing a loop for a while and I drafted up a loop in a Switch 810 ended up with this
was thinking res>pump>240mm>GPU>CPU>360mm>res no idea if thats good or not being a bit of a noob
and id put together a list of potential components and wanted to check them past some people a bit more knowledgeable than myself, I had planned on using:
1x Koolance CPU-380I
1x Koolance VID-AR797 (not sure about that one) or an XSPC Razor
1x Bitspower Z-Multi 250mm res (again not too sure about that one)
11x Bitspower 1/4" thread compression fittings (3/8"ID 1/2"OD)
some Primochill PrimoFlex Advanced LRT
XSPC EX series radiators
and an XSPC D5
with either a Biocide or Silver Kill Coil
id be cooling a 3570K, overclocked obviously and a 7970 similarly overclocked, if you have any suggestions on any of the components, or a smaller case that would still fit enough rads to cool the components well id apreciate it
Im not 100% sure ill even bother with it though id still like to check with some others for if I do, tanks in advance
give a man a gun he robs a bank, give a man a bank he robs the world
https://linustechtips.com/topic/10398-possible-custom-loop/
I am by no means an expert, but just from reading the beginning of your post order doesn't really matter as the water is moving so quickly, and from what I know you may want to flip that front rad so it can bleed easier, bubbles are going to get caught in the top and you're going to have a hard time getting them out. I can't really add any input on the parts, as I don't have any experience. Just my two cents.
My Rig:
Cooler Master Storm Trooper -  Asus Sabertooth Z77 -  I5 3570K @ 4.5 Ghz - Sandisk Extreme 120GB SSD - A few random HDDs from old laptops - Hyper 212+ - EVGA GTX 680 4GB - 8 GB G.Skill Ripjaws 1333 - SeaSonic 750 Watt Gold PSU - Three 24'', one 19'', 15'' and 13'' monitors
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-112010
Thanks, so I want the rad with the ports at the top now just need someone to look at the components and hopefully find a smaller case, not that there is a problem with the switch it is just a bit big even if I can fit it
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-112401
All you components look ok - Bitspower are a quality brand name, as is the Koolance and XSPC. I am partial to the razor blocks - I like the look of those.
​Cases wise, most people are very particular about the case they want and then see what they can fit in it. The Fractal Define XL r2 is a nice case that can hold a couple of rads. Best bet, do a search on cases. Bunch of threads on that topic. :)
Also - probably need 12 compression fittings - each component needs two. And as Milta mentions, if you can, mount the front rad with the ports at the top. For order, make sure the outlet of the res feeds into the intake of the pump, so it won't run dry. Other then that, order doesn't matter - whatever works. Typically though, make them as short and neat as possible...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-112423
All you components look ok - Bitspower are a quality brand name' date=' as is the Koolance and XSPC. I am partial to the razor blocks - I like the look of those. ​Cases wise, most people are very particular about the case they want and then see what they can fit in it. The Fractal Define XL r2 is a nice case that can hold a couple of rads. Best bet, do a search on cases. Bunch of threads on that topic. :) Also - probably need 12 compression fittings - each component needs two. And as Milta mentions, if you can, mount the front rad with the ports at the top. For order, make sure the outlet of the res feeds into the intake of the pump, so it won't run dry. Other then that, order doesn't matter - whatever works. Typically though, make them as short and neat as possible... [/quote']
Thanks, I think I might go for the Razor I think it would generally fit in better and its a little cheaper than the Koolance block any suggestions on a back plate? shame XSPC dont do them their Titan block and Back plate look quite nice.
I put together a few more revised loops (Apologies for my horrible MS Paint skills) two in the Switch 810 and one in a TJ07 which may be a little expensive
Firstly a revision of my original loop with the suggestions already made
2nd something I have seen in a few loops in the Switch 810 with a 240mm along the bottom rather than the front and the pump in between it and the res
And finally the TJ07, I found a place here in the UK that will sell me one fully powder coated and modded to have room for a 30mm thick tripple rad in the roof for a reasonable price now this one has a lot more simple runs though I think i would probably need to either employ some angled fittings in the bottom or just some clever tubing routing (sorry for it being so small its strange how hard it is to come across a picture of one empty in a decent size)
this would mean replacing the XSPC 240mm with a thinner 360mm rad like a Black Ice GT Stealth, any suggestions on that or is that a good one?
also how often would I be looking to maintain it? from what ive read every 6 months is typically recommended, would you agree with this, should it be done more often or even less often?
Also ive heard some things about Primochill tubing having issues with the Mayhems Pastel coolant and some issues with the plasticizer is there any truth to this and if so would you recommend Alphacool AlphaTube HF?
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-113292
nix the BIGT for an alphacool ST360. similar fin count as the XSPC, so using the same fan
throughout the build is better than having screaming fans on one and low-speed on the other.
using the primochill "advanced" seems to be ok with the pastel. the XSPC hi-flex is great hose.
airdeano
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-113340
airdeano
Found it
http://www.specialtech.co.uk/spshop/customer/Alphacool-NexXxoS-ST30-360mm-Triple-Radiator--Full-Copper-pid-15305.html
thanks for the suggestion
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-114013
Hey Kruziik, it's good to see you here. Considering moving over here full time as our old forum is falling apart :(
Anyway, to help with case choice, Fractal Arc Midi V2 is a great watercooling case, and it's smaller than the 810.
EDIT: I'm lieutenant BTW
Asus M4A89GTD PRO/USB3 | AMD Phenom II X6 1090T @ 3.9GHz | Sapphire Radeon HD 6870 & Club3D 7950 RoyalKing in the same rig. such dogecoin miningz | 8GB Corsair XMS3 1600MHz | Corsair H70 | Antec P280 White Windowed | Asus Xonar DG | Samson SR-850 | Blue Yeti
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-114095
The TJ case is really nice - you 2nd switch layout is similar to what I have in mine. As airdeano says, go for the alphacool rad. I myself use the XSPC tubing, no issues. For maintenance, depends on a few factors, but I typically plan on once per year. If you case is somewhere where it gets a lot of direct sunlight, maybe 9 months...
For a back plate - find one that fits and looks nice. They have no functional value. Heatkiller makes some nice ones.
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-114183
The TJ case is really nice - you 2nd switch layout is similar to what I have in mine. As airdeano says, go for the alphacool rad. I myself use the XSPC tubing, no issues. For maintenance, depends on a few factors, but I typically plan on once per year. If you case is somewhere where it gets a lot of direct sunlight, maybe 9 months... For a back plate - find one that fits and looks nice. They have no functional value. Heatkiller makes some nice ones.
Thanks again for the advice, Would you suggest going 3/8"ID 5/8"OD with the XSPC Tube? also thoughts on the XSPC EC6 coolant? its a fair bit cheaper than the Mayhems coolant and from what ive read so far things look promising and it being UV reactive I might invest in clear tubing and some of those Phobya UV LED strips, struggling for a back plate Heatkiller look pk but I dont think they would really fit in with the Black/Blue id be going for though there would be some hints of silver from the Koolance CPU block ill most certainly look into it more
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-118120
Check performance-pcs.com - they seem to carry a lot of back plates. Give you some ideals. As for tubing, I am using XSPC clear with EK UV cooling. I would assume though the XSPC coolant be a good quality as well. I went 7/16" ID on mine - what came with a kit and compression fittings - so I pretty much stick with that for compatibility. The 3/8" though should be fine as well.
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-119782
Firstly people who have issues with this are either complete idiots and don't read or very unlucky. If anyone went to mayhems website this is the warning that takes up half of the pastel coolant page:
Before Using Mayhems Pastel range
The system must be clean and have no chemicals of any kind left in the loop. There must be an absence of bleach, biocide and anti corrosive inhibitors. We recommend you flush your system with either DI water or Mayhems Ultra Pure H20 before use. Mayhems Pastel has biocides and inhibitors included within the mixture.
Do not use Mayhems Pastel with Primochill tubing or Tygon tubing as Mayhems Pastel seems to react with it changing the colour of the tubing to a greenish colour. This is not the fault of Primochill, Tygon or Mayhems it is just a incompatibility issue. Pastel works fine with XSPC, Thermochill, Clear Flex, Masterclear and a few other brands.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-120054
Right so im now looking at:
1x XSPC D5 Vario (body+Screwring)
1x XSPC Acetal Top for Laing D5
1x XSPC EX Series 480mm Quad Radiator (TJ07) / XSPC EX Series 240mm (Switch 810)
1x Alphacool Nexxos ST30 360mm Tripple Radiator (TJ07) / XSPC WX Series 360mm (Switch 810)
1x Alphacool Nexxos GPU Backplate
1x Koolance CPU-380I CPU Waterblock
1x XSPC Razor 7970 GPU waterblock
1x Bitspower Z-Multi 250mm Reservoir
12x Bitspower 1/4" Thread Compression Fittings for 3/8"ID 5/8OD Tubing
3x Corsair SP Series PWM High Preasure Fan Dual Pack (2x For Switch 810)
1x Corsair SP Series PWM High Preasure Fan
XSPC High Flex Hose 3/8″ ID, 5/8″ OD Clear / Blue
2x XSPC EC6 Non-Conductive Coolant 1L UV Blue
1x Arctic MX-4 Carbon Based Thermal Compond
Crap for cleaning thermal compound
possibly investing in some angled fittings
and the last layouts I posted for both cases, any other suggestions?
also just wanted to say you guys have been a really great help
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-128987
I highly recommend the Heatkiller 79X0 water-block just because it looks amazing and has one of the best performance vs. restriction ratios afaik.
Personally use it, the backplate they make also looks amazing.
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-129023
If you are going XSPC GPU block, doesn't the Razer have the LED? Then go with XSPC CPU block - same thing, can get it with LED to match. :D
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-129549
I do agree the Heatkiller looks quite nice and it is a very good block, but im not sure it would really fit with the mostly Black/Blue components, though in saying that the CPU Block unless I went for the XSPC Block so that it matches does have some silver so it may fit ill need to look into it a bit more
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-135037
you can easily wrap the HK top plate in a color to match the build. it is not permanent
and can be detailed to the nine's.
airdeano
https://linustechtips.com/topic/10398-possible-custom-loop/#findComment-135258
