I tried overclocking the Radeon HD 7650m on my Probook 4441s. Both the core and memory clock capped out at its stock speeds. So I went to the settings and enabled unofficial overclocking without powerplay (also tried with but didnt work). But the core and memory sliders showed 0 (not +0) and didnt allow me to change anything. I know some people have done it and it seems like there is some overclocking headroom. Im running the radeon crimson version 2016.0226.1531.27895 and driver version 15.301.1901.0
I tried the WHQL Catylist one but it didnt work either.
Specs:
Intel Core i5-3320m
2x4GB DDR3
AMD Radeon HD7650m
500GB Seagate Momentus
Main Desktop:
Intel Core i7-13700KF (5.5GHz, -0.1v Offset), Lian Li Galahad 360 AIO, Asus ROG Strix Z790-A Gaming WiFi, Gigabyte RTX 4070 Ti Super Aero OC, 2x16GB G.Skill Trident Z5 RGB DDR5-6000 CL36, 4TB Samsung 990 Pro, Corsair RM850x Shift, Phanteks NV5 w/ Lighting Kit
Peripherals:
Alienware AW3423DWF QD-OLED, Logitech G502 X Plus, SteelSeries Aerox 3 WL 2022 Snow, HiFiMan Sundara, Sennheiser HD 560s, Cooler Master MH630, Schiit Modi 3e, Schiit Magni Heresy
Laptops:
Asus ROG Zephyrus G14 (Ryzen 9 8945HS, RTX 4060)
Phones:
Samsung Galaxy S24 Ultra 256GB, iPhone 14 Plus 128GB
https://linustechtips.com/topic/1039777-need-help-overclocking-7650m/
Overclocking a cheap laptop is a bad idea most of the time.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
If its not stable or the temps are too high i would set it back to stock. I just want to see if there are any significant performance improvements.
Main Desktop:
Peripherals:
Laptops:
Phones:
There might be performance improvements for a few minutes but IMHO the machine will get hotter quickly and your core clocks both on CPU and GPU will go down to even lower than they we're before...
If you can undervolt AND overclock the GPU...maybe.
I cant undervolt the cpu either unfortunately. XTU doesn’t give me the option to and fivr on throttlestop only supports haswell and above. So it appears that there is nothing much that i can do.
Main Desktop:
Peripherals:
Laptops:
Phones:
Also someone has done it on a Probook 4540s and they seem to have gotten a decent fps boost. Its on youtube somewhere but i cant find it at the moment:
Main Desktop:
Peripherals:
Laptops:
Phones:
I have HD6770M a.k.a HD7690M XT which is basically a binned HD7650M and i have no problem overclocking the GPU using Catalyst driver.
Also you need to run some 3d app to let MSI Afterburner read the clock speed. I usually run GPU-Z render test.
The issue is that msi afterburner can detect the clock speed and the memory speed and shows it on the dials but i cant change anything on the sliders which reads 0. It might be an issue with the dual graphics but i don’t know how to resolve it.
Edit: Tried it but didnt work
Main Desktop:
Peripherals:
Laptops:
Phones:
Mine also come with dual graphic.
I use Catalyst 15.7.1.
This is my MSI AB setting.
without extend official oc limit.
with extend oc limit
actual overclock
  Reveal hidden contents
actual overclock
Here is what happens when before and after I enable unofficial overclocking
Main Desktop:
Peripherals:
Laptops:
Phones:
Just tried disabling unofficial overclocking and using extend official overclocking limits but the box becomes unchecked again when i restart afterburner
Main Desktop:
Peripherals:
Laptops:
Phones:
Are you on Radeon Crimson driver? DDU and install Catalyst 15.7.1.
Tried that already. But I just realised the standard 7650m has 1gb of vram while mine has 2gb which should be exclusive to HP. I’ll try the drivers on HP’s website and see how it goes.
Main Desktop:
Peripherals:
Laptops:
Phones:
I tried again with the HP drivers but it still remains the same. Unofficial overclocking leads to 0mhz, extend official overclocking limits keeps becoming unchecked.
Main Desktop:
Peripherals:
Laptops:
Phones:
