Really depends on your preferences.
I've used Xbox One and PS4 Dualshock on W10 through blu-tooth.  Steam has the ability to see and map both.
2023 BOINC Pentathlon Event
F@H & BOINC Installation on Linux Guide
My CPU Army: 5800X, E5-2670V3, 1950X, 5960X J Batch, 10750H *lappy
My GPU Army:3080Ti, 960 FTW @ 1551MHz, RTX 2070 Max-Q *lappy
My Console Brigade: Gamecube, Wii, Wii U, Switch, PS2 Fatty, Xbox One S, Xbox One X
My Tablet Squad: iPad Air 5th Gen, Samsung Tab S, Nexus 7 (1st gen)
3D Printer Unit: Prusa MK3S, Prusa Mini, EPAX E10
VR Headset: Quest 2
Hardware lost to Kevdog's Law of Folding
OG Titan, 5960X, ThermalTake BlackWidow 850 Watt PSU
Yep.
Also, DS4 Windows can spoof xinput for DS4 controllers for non-Steam games, allows the LED strip to be RGB colorized, enables motion controls, and the touch sensor can be configured as a mouse.
That said, in terms of functionality, DS4 is better than the Xbone controller. But as far as everything else, it honestly comes to preference.
Gaming Rig
CPU: Intel i7-6850k @ 4.2GHz
GPU: 2x FE GTX 1080Ti
Memory: 16GB PNY Anarchy DDR4 3200MHz
Motherboard: ASRock X99 Extreme 4
Encoding Rig
CPU: Ryzen 7 1700 @ 3.7GHz
GPU: GTX 1050
Memory: 8GB Curcial Ballistix DDR4 2133MHz
Motherboard: Gigabyte AB350M-DS3H
23 hours ago, hbsterling said:
I am trying to buy a wireless controller. I was one that will natively work without an adapter on windows 10 steam gaming and also the steam link. Any suggestions?
parroting everyone else... Playstation 4 or Xbox One are probably your best bets. Whichever one you like the feel of is what I would recommend.
I use PS4 controllers wirelessly, have an Xbox One Elite controller (usb'd) for most Windows games, a bluetooth SNES controller for SNES/NES emulators, and a usb to N64 adapter with one of those new RetroFighters redesigned N64 controllers for N64 emulators.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
I found the Xbox One controller get the full compatibility with Windows 10, but I still have a problem with its shoulder T & B buttons, T = Top but it's actually located at the bottom, and the B = Bottom it's actually located at the top.
I really don't understand why Microsoft made it like that. It disoriented me, and makes me difficult to get used to it, as I'm not a console guy..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
