Cases that'll fit a TFX Power Supply and mATX board?
If you go to PCpp you can select a tfx PSU and then your case selection will be automatically filtered. Give it a shot
Primary PC:
23 minutes ago, NunoLava1998 said:
How about the Inwin CE685 FH300TB3? Though it has a included TFX PSU already
thanks that does seem compatible, but its got the same aesthetics as the current OEM case so no reason to swap it. I was thinking something along the lines of a more traditional "gamer" look to appeal to the kids.
as for swapping to normal ATX, that's certainly possible, just adds additional cost.
You can run a mATX board in an ATX case if cost is a concern.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
its the power supply i'd want to re-use as it has a TFX power supply with a 14pin mobo connector.
if i swap to an ATX power supply im looking at £50 for the PSU and £15 for the adapter. so thats £65 worth of stuff i don't actually need
