Quiet, and budget friendly you say?
The be quiet! Pure Wings 2 PWM come in 120 and 140 sizes and are quiet, don't cost too much, and move a lot of air.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1036759-fan-reccomendations/#findComment-12326906
Well, the be quiet silent wings are pretty good. Or pure wings for airflow optimized.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1036759-fan-reccomendations/#findComment-12326908
Are pure wings quieter than the hyper 212 evo haha. If not ill just get silent wings.
I hAve an unfinished pc build. Pls dont bully for not having one yet or i cry.
https://linustechtips.com/topic/1036759-fan-reccomendations/#findComment-12326920
On the hyper 212 I would use silent wings because they're for static pressure. I do believe they're a bit quieter.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1036759-fan-reccomendations/#findComment-12326924
The hyper 212 evo has semi-loud fans, but they're loud compared to the be quiet fans
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1036759-fan-reccomendations/#findComment-12326926
How cheap is considered budget? On the cheap side there's the Arctirc F12 and F14, ok performance, low noise levels, very cheap. If you can pay more for use-oriented designs (static pressure optimized vs airflow optimized, former pushes air harder, latter pushes more air) then I'll recommend Phanteks MP fans (pressure), Fractal HF fans (airflow) and the Noctua S series fans (the grey ones, also airflow).
I don't like be quiet fans because they drop speed and performance compared to other fans in other to achieve lower noise levels, which I think is stupid because motherboards (excluding those on mass produced prebuilt systems) support fan speed control and you can slow fans down manually, achieving the same result while still having the ability to blast the fans for maximum cooling if needed.
Desktop benching:
https://linustechtips.com/topic/1036759-fan-reccomendations/#findComment-12326933
They are set to standard and I can hear them. I have them on silent right now and it’s still quite loud.
https://linustechtips.com/topic/1036759-fan-reccomendations/#findComment-12326935
