Two case fans usually does the trick for a budget system, be quiet silent wings is often cheap and good.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12326752
Why a G CPU if you added a graphics card though...
You should have at least 1 intake and 1 exhaust
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12326753
Cheaper and better than Ryzen 3 1200
Primary PC:
PSU tier list
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12326759
Just now, DarkAngel56 said:
the pc hase 3 fans 2gpu and 1 cpu
Yeah but those aren't case fans so you'll need to add some, you need airflow in and out of the case.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12326765
Who said anything about a 1200?
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12326767
Well if OP had chosen a non-g CPU for this build, it would likely have been the 1200, but the 2200g is better and cheaper so even if it has integrated graphics it was sensible to pair with a discrete GPU.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12326773
5 minutes ago, manikyath said:
whatever the included number of case fans with your case is will be good.
and if your case did not have any case fans included, you most likely bought a terrible case and should add 1-2 case fans.
i am literly runing the pc now and has no problems and if something goes wrong ill use there 5 year warranty but i will probably get 1 fan but for now no case fans. and 1 more thing can i have a tv that i have pluged the hdmi will it be a problem if i play on the mobo hdmi.
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12326889
it wont spontaniously die from running hot, but moving hot air out the chassis (and exchanging it for cool, fresh air) is part of keeping the box running optimally.
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12327340
Generaly speaking 3 is a good start.
2 As intake (usualy at the front), and 1 as exhaust (usualy at the back).
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1036746-how-many-case-fans/#findComment-12329612
