Hey everyone I’m new to PC building but recently I got a deal on two GTX 1070’s so I went out and bought a motherboard I ended up getting a msi mpg z 390 gaming pro carbon. I would like to use both graphics cards in sli i am looking for any Recommendations for a CPU a power supply and also the ram requirements any help would be great thank you
https://linustechtips.com/topic/1035310-first-pc-build-looking-for-advice/
16gbs of RAM would work for a system of that caliber. I would get a high end Ryzen cpu or a mid range intel cpu. I also would get at least a 750 watt psu as well. I would recommend putting this build in pcparkpicker to check for compatibilities. Good luck on your build!
If you're going to SLI GTX 1070s, you may as well get an i9-9900K to make sure they're well fed. 16GB of RAM minimum, speed is less significant on Intel than on AMD, but I'd get at least a 2800 kit for good measure. 3200 woudn't hurt by any means, and is reasonably priced. Power supply would require a 750W minimum, and I would probably swing for a 800-850W personally. It would be a bit of a waste to go with anything below 80+ gold, and I'm a big fan of pure digital.
Dude he said he has a Z390 board.
If it were me yes 16Gb of any decent speed ram (2666 MHz or higher) and for a cpu a few options:
  1. i7-8700K if you plan to eventually upgrade your system and aren't looking to piss away $500 on a Core i9 9900K
  2. i7-9700K if you plan on gaming and streaming a lot and don't have any reason for 8C /16T
  3. i5-9600K If you need something for straight game and overclocking.
Remember that none of these chips come with coolers so you have to get an AIO or do some sort of high fin density cooler.  Sorry I know this is a lot to digest at once.  For a PSU aim for a Gold or Platinum 850 Watt or higher, because those cards draw 200+ Watts if my memory serves me right and if you overclock one of those chips you're looking in the high 600's for a draw.  Hope this helps :)
Main PC: Ryzen 7 7800X3D | 32GB GSkill 6000 MT/s | B650E TUF Gaming WIFI | 2TB Samsung 990 Pro | 2TB Samsung 990 EVO | Gigabyte OC RTX 4080 Super | Corsair 5000D Airflow |                  1000w Seasonic GX | Windows 11 Pro
Laptop 1: Macbook Pro 14" M3 Pro | MacOS 15.x
Laptop 2: Razer Blade 15" Base 2021 | Windows 11/Pop! OS 22.04
Servers 1-3: Super Micro 813MFTQ-441CB | Xeon E5-2650 v4 | 128GB of ECC DDR4-2133 | 2x 250GB Micron 5200 MAX | OS: Proxmox 8.x |
Server 4: Dell DP4400 (R740xd) | 2x Xeon Silver 4114 | 64GB of ECC DDR4-2400 | 2x Crucial MX500 (Boot) | 2x Seagate Exos 18TB, 1x WD White Label 18TB, 5x 14TB Seagate Exos,                          2x Samsung 870 EVO 500GB (L2ARC), 2x Samsung 863a 960GB (S Log)
He already has a Z390 motherboard...
Let's get an Intel CPU that will work in it. And SLI GTX 1070s should get at least an i7-9700.
He has a Z390 board
Did I break it down well above?
4 minutes ago, GateToTheFuture said:
He has a Z390 board
I'm not sure you're responding to the right person. I made the same point as you, in contrast to Elevate's suggestion of an AMD.
How did you come to that figure?
9 minutes ago, Jord179001 said:
Awesome thanks I am also looking at the i5 9600k or a i7 8700k any thoughts ?
Good all around
4 minutes ago, Jord179001 said:
Are there any power supply brands to avoid?
Avoid everything except cosair, evga, seasonic or silverstone.
While I may not be the smartest I know a z390 isn’t an am4 chipset, he could also purchase a new mobo and return the older one.
Rough brain math. TDP on the 1070s is 150 in stock form. The 9900K is 95W theoretically, and in stock form, misc power for the system, theoretical BARE minimum is probably 500W. Any overclocking will increase that number pretty drastically, and pretty quickly, and power supplies are their most efficient between fifty and seventy five percent. Relatively off the cuff.
WHY?!? Intel has better IPC, better max clock rates, and ostensibly the best performance for gaming.
Have you ever questioned value? OP might have spent most of the money towards the motherboard and 1070s
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
I have not, I have a 2600 in the system I'm typing from. And a 2400G in the system I just built for my nephews. And a 200GE(which I admittedly overpaid for on ebay) getting ready to go into my new home media server.
However the presumption that he could, or would want to return a perfectly good motherboard that he already picked out, to get the better value, is borderline preposterous.
Honestly I don't see it as bad, but thats just for OP's case. I think this, because he has a $220 (on newegg) motherboard that he could sell and get a way better motherboard that costs less. A Gigabyte Aorus Z390 Elite is significantly cheaper and overclocks much better than the MSI board and even the Asus Maximus Hero XI.
Also I think he should sell the 1070 because SLI is not a good choice right now (power consumption, low support in games).
8086k
aorus pro z390
evga 3070 ultra
