Custom Loop - Mod AIO Cooler
On 2/22/2019 at 11:14 AM, Blai5e said:Don't mix aluminum and copper... the radiator you listed is aluminum and the GPU block is copper or you'll be inviting galvanic (dissimilar metal) corrosion to the party.
Go for full copper or full aluminum only in your loop.
the AIO Rad is the same as the Rad I got... they are both Aluminum... I am pretty sure its a copper plate on the outside... it screws in.... Cooler Master is probably aware of mixing metals...
THE TEST WORKED!
so with an AIO cooler broken apart, I have the res feeding the pump/cpu block, into 360 then into 240 and back into the res ... flow is really decent .. STAYING firmly around 30c on idle
8 X RGB Case Fans
Modded Corsair TX650M to take an RGB case fan
Getting a GPU water block in tomorrow
2 x 3tb hdd in RAID 0
2 X NVMe boot drives in RAID 0
on a Ryzen 7 1700 Oced to 3.9 with 1.875 v and 3200 Mhz Ram
Tomorrow I have Water Cooled Founders Edition GTX 1070
NOT BAD!! Not bad at all...
