Hi everyone,
In September I will be promoted at work so I will get a pay rise & to celebrate I will be building myself a new gaming rig & it's just not worth upgrading my current rig (i5-4690K)
I like my technology to be clean & minimalist & I will be doing a white & purple build, I've worked out most of the components I will be using but I'm unsure about the Case, Mobo & variant of GPU (I will ask in those forums)
In terms of case I straight away went to NZXT in particular the H500i as its literally the most clean minimal case I can think of, however I've also seen the Lian Li O11 Dynamic, I've seen extensive videos on both cases & I really can't make up my mind, in terms of size I don't want anything too big as my current case is HUGE, a Bitfenix Shinobi XL.
In terms of what I will be putting in this case I will be putting in:
ATX Motherboard
AIO CPU watercooler
RTX 2080TI (normal size card)
So I have two questions to ask:
1. Are there any other ATX cases that are white, with a clean minimal design?
2. What case should I pick, I know the Lian Li can have issues with the adhesive on the front glass panel & there are some airflow issues on the H500i
Also I live in the UK so availability may be an issue however I will import if I must.
Thanks again for your help on this
Jon
https://linustechtips.com/topic/1033265-help-please-minimal-design-cases/
I have the H500i white, is very nice.
No problems with airflow,I just recommend you use two 140mm fans.
1. The Phanteks P400 is pretty minimalistic, but I think the NZXT H500i looks better.
2. I have the H200i (essentially same case just smaller) and I love it, so I would go with the H500i. The only issue I had was with mounting a radiator on the front of the case, i'm sure I was just being dumb that day, but it took me 5 tries to get it mounted in properly.
Also, congrats on the promotion
Are those mounted on the front?
1. Looks pretty nice, I'll take a further look.
2. How have you got the fans on intake or exhaust?
Thank you :)
In the front I have two 120mm fans intaking air though a radiator, and in the back I have a single 120mm fan exhausting air also through a radiator (I have an AIO on my CPU and my GPU is a hybrid water cooled card). I've been using it like this for the past 5 months, and have had no issues with thermals. There is also the option to mount fans on the top as intake/exhaust.
That's what I've been thinking as well so thanks for confirming that's fine, although I won't be water cooling the GPU so I'm sure it'll still be fine.
Yeah.
Fractal Design is known for their minimal design cases, but I am afraid that they don't really have anything to offer in your case – their white cases have black elements and you either get a compact ATX like a Meshify C or a basically E-ATX like Define R6/S2. Although Define R5 might be worth looking at (thermals won't be great).
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
How about Corsair Carbide 330R?
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
Noooooooo, do not get the P400/P400S! The front panel means almost 0 intake air. I had a P400S and just bought a Meshify S2 to replace it because temps were so bad.
The original non-S2 Meshify is fairly cheap and is great, +1 for that.
i9 9900K @ 5.1 | AsRock Z390 Taichi | MSI GTX 1080 Ti | 16GB G.Skill Trident Z DDR4-4133 | 1TB Muskin Pilot NVME | 1TB Samsung 860 Evo | 5TB Toshiba X300 | Fractal Design Meshify S2
i7 860 @ 2.8 | Advantech AIMB280 ITX | EVGA GTX 950 2GB  | 2GB Kingston DDR3-1333 | Hitachi 500GB | WD 320GB | Silverstone SFX-L | Silverstone RVZ01
Is that brexit related? I don’t think the UK has many issues getting cases.
I think your minimal is actually quite fancy.
I love the minimal design of Fractal cases so I have an windowless Nano S. It’s superb looking while having great thermals and good sound dampening. The C series is also quite good but I have heard the R5 is not that good vs R6.
Proper minimalist is plain colour, no window IMO.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
No reason with Brexit in particular but some GPUs for example aren't available here only NA for some reason.
Yeah I should have specified a window because i'm a basic bitch but clean is probably the word that suits what I want best.
Thanks again for your suggestions.
Don’t forget to show the finished product, personally I like your colour choice and would love to see how it looks in the end.
One day I may build a flashy PC with a window and lighting but probably not for a while.
Oh I will don't worry.
Below is a link to my current PC that I build in 2014 on a very strict budget of £900 which i will be replacing.
I want to go 1 step further with aesthetics this time so I want it to be perfect.
https://uk.pcpartpicker.com/b/2QvV3C
