Changing my AIO fans?
Solved by TH3R34P3R,
1 minute ago, Darprix said:Hey!
Do you think it's possible to change my ML240R fans with Corsair LL fans? I don't really like the Cooler Master fans.
as long as the mounting spots are the same (all fans should be) then yes. you can switch them.
Featured Topics
VinSen ·
Posted in New Builds and Planning1 -
1
Fahizzle ·
6
INotPablo ·
Posted in CPUs, Motherboards, and Memory1 -
nugget1414 ·
Posted in General Discussion0
