So I have a problem with BF4
okay so I can start up multiplayer just fine, get a server just fine, but one issue has appeared... I can't deploy, at all, I have had this game for awhile and this has just now become an issue, so anyone know how to fix this?
MoBo: 970A-D3P CPU: FX-8350 GPU: HD 7950 PSU: 1000watt RAM:8Gb of G,skill 1600
https://linustechtips.com/topic/103196-so-i-have-a-problem-with-bf4/
That's the first I've ever heard of that.
Try fixing your install and if that will not work then re download punkbuster and install it! It is a punkbuster thing it is stupid....
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
Repair the install. Failing that, reinstall.
Laptop Lenovo Thinkpad X220 - CPU: i5 2420m - RAM: 8gb - SSD: Samsung 830 - IPS screen Peripherals Monitor: Dell U2713HM - KB: Ducky shine w/PBT (MX Blue) - Mouse: Corsair M60
Audio Beyerdynamic DT990pro headphones - Audioengine D1 DAC/AMP - Swan D1080-IV speakers
Update Punk buster
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
have to ask how do I update punkbuster itself?
On their website you download installer then add BF4 then click update
Hope I could help!
There has to be a fix, because this is not a common problem.
but a new issue has arisen, once I die I can't respawn, won't take me to deploy menu
update punkbuster I just had to do it for the same problem. There are warnings all over battlelog about it.
Motherboard: MSI-990FXA-GD65 | CPU: AMD FX-8350 @ 4.3Ghz | CPU Cooler: Corsair H100 | RAM: 8GB Corsair Vengeance 1600Mhz | GPU: MSI GTX 770 Lightning @ 1300Mhz CC and 8000Mhz MC | Case: Fractal Design ARC Midi R2 | PSU: Corsair AX850 | OS: Windows 8.1
Just out of curiosity, this is a legally purchased copy right?
