Cleaning 2 week old thermal paste?
Solved by Cyberspirit,
3 minutes ago, ShadowN96 said:its just the paste that comes with the stock wraith stealth
You'll be fine. Just get a paper towel and pour some on it then wipe the paste off. You don't need to worry about the sides just the top of the IHS.
Once you wiped it all down just wait for a little and then apply the new paste.
