Cpu cooler fan 100% RPM problem
In most of fans there's almost always a +/- 10% rating for their max speed, that means it can be 10% less or more than the rated max speed just like this,
In other case it can be more than +/- 10%, it's between 10-20%. For example of this case is my own NF-A14 3000 RPM, on its official spec it's stated as +/- 10%, which is it can be 300 less or more so it should be 3300/2700 RPM based on the spec, but in reality I found that its max speed is 2500RPM which is 17% less than its official rated max speed.
If you ask, why I use this 3000 rpm fans because it will be noisy af., I need static pressure as much as possible to cover what people and reviews says about my PC case which has bad front intake airflow, but I ended up found it's underrated, and the noise of the Noctua iPPC fans is overrated. So all my PC components got a breeze inside the PC case.
