Upgrading from 1080 to 2070 for small difference
Solved by Stormseeker9,
Can recommend the 2070’of MSI. Never has run a hair hotter than 69c. Under load at 1440p, highest settings everything enabled. On idle it sits around 29-31c. (At times it idles at 23-25c depending on ambient)
You’ll have about 8-11% gains over an 1080 + you are able to use Ray tracing + DLSS down the line once more adopted.
Featured Topics
rlaphoenix ·
Posted in Displays0 -
ulookuglynoob ·
Posted in Mobile Gaming0 -
I eat limes often ·
Posted in Laptops and Pre-Built Systems1 -
DudeSquad11 ·
Guggenheim. ·
Posted in Troubleshooting2 -
1
Chickooj ·
Posted in Peripherals0 -
5
