Hello.
I recently bought (a week ago) an Asrock RX 580 Phantom Gaming D. This one:
https://www.asrock.com/Graphics-Card/AMD/Phantom%20Gaming%20D%20Radeon%20RX580%208G%20OC/
My PSU was the EVGA 500 but it died today when my brother was playing AC Syndicate
I think it was because of the graphics card having only a 6pin connector when any RX580 has a 180W TPD. But I'm still a novice when it comes to PC gaming so I don't really know.
I'm kind of scared because I don't want to buy another PSU and lose it the same way
In case it helps these are the other parts of my PC:
MB: Asus M5A88v-evo
CPU: FX 6300
RAM: Kingston DDR3 1600mhz 2x4Gb
Is it a graphics card's design issue?
Any thoughts?
Sorry about my english.
https://linustechtips.com/topic/1029818-rx-580-6pin/
Nothing wrong with the graphics card, when you buy a new PSU get a 550 or 600w gold rated PSU so it doesnt blow up or die, what rating did the PSU have?
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
https://linustechtips.com/topic/1029818-rx-580-6pin/#findComment-12265715
I'm running R5 1600 + RX580 in a poor 450w psu.
Power calculator suggested 360 watts (420 watt recommended).
https://linustechtips.com/topic/1029818-rx-580-6pin/#findComment-12265726
The standard one. And is tier 6 in the PSU tier list. Pretty bad.
The 6pin connector thing is giving me headaches because the Asrock RX 580 Phantom X has a 8pin connector.
Do you think that the 6pin connector is able to supply the power that the graphics card needs?
https://linustechtips.com/topic/1029818-rx-580-6pin/#findComment-12265748
Do you think that the 6pin connector si able to supply the power that the graphics card needs?
if it has a 6 pin on the gpu yes
https://linustechtips.com/topic/1029818-rx-580-6pin/#findComment-12265757
2 minutes ago, Wormhole said:
are you using a 6 pin when the gpu requires a 8 pin? a six pin wont supply enough power if the GPU is 8 pin.
The two additional pins from 6-8 pin pcie are actually ground lanes so there shouldnt be a problem with power delivery altho a 6 pin is meant to deliver 75W and a 8 pin 150W
https://linustechtips.com/topic/1029818-rx-580-6pin/#findComment-12265781
RMA that psu if you still have warranty. If you have a case with limited airflow where that cheap psu acted as an additional exhaust fan, its quite normal for it to fail in 5 years.
And if you buy a new psu, buy one with decent stuff inside as it will last longer. Seasonic focus plus, Evga g2/g3, Corsair rmx/Vengeance, new Antec hcg(based on seasonic focus plus). Some have 10 year warranty.
https://linustechtips.com/topic/1029818-rx-580-6pin/#findComment-12265795
Yes, I definitely need a high quality PSU but I still have the doubt if the 6pin connector will be enough for the card whatever the PSU is.
Like I said, I'm scared to spend a lot of money on a new PSU and lose it because of the graphics card.
https://linustechtips.com/topic/1029818-rx-580-6pin/#findComment-12265864
What makes you think adding 2 ground wires would save the psu?
https://linustechtips.com/topic/1029818-rx-580-6pin/#findComment-12265877
