1. Be sure to double check the names of your variables (I see 'radius' and 'raidus', not sure if both are meant to be the same one).
2. On your "getRaidus" method, you declared this method as being a  'void' method, but you are using a return command. This doesn't match. You use 'void', if you are making a method that doesn't return anything, but you would use 'return' if you called on this method from somewhere else and needed to return a variable of some sorts.
I'm not sure what you are doing here, but I think in the 'getRaidus' method, you might just want to give your variable a value, or display it. Not use return.
This is what you are looking for:
public class Ring {
  // This is a field of Ring object
  private final double radius;
  // This is a contstructor
  public Ring(final double radius) {
    this.radius = radius;
  // This is a method. Note the 'double' return type.
  public double getRadius() {
    return this.radius;
  // This is also a method. Note the 'return' keyword.
  public double computeCir() {
    return 2 * Math.PI * this.radius;
  1. Watch for typos. Method names and variable names must match between definition and access.
  2. Java does not allow nested method definitions.
  3. To avoid confusion, I recommend referring to instance variables (fields) with "this." prefix.
  4. Things that are not supposed to mutate should be marked immutable explicitly using 'final' keyword.
  5. Methods must have return types. Your code sample was using void in places. Void means "returns nothing".
  6. Return keyword is mandatory in Java.
Also, try to write code incrementally while learning and avoid copy pasting - write small chunks, test if it works, repeat. Otherwise you end up with several unrelated issues that might be confusing to fix.
Working example: https://repl.it/repls/FatherlyFairAggregators
Brackets brackets brackets. Your constructor has unclosed brackets.
Void in the first function should be double.
The last function has spelling error. Or rather, your instance variable has spelling error.
Sudo make me a sandwich
