System not posting :/
Go to solution Solved by LukeSavenije,
we've got you covered
PC:
MSI B450I GAMING PLUS AC
Ryzen 3 2200G + stock cooler
2x 4GB DDR4 HyperX 2666MHz
500GB 860 EVO SSD
a 450W psu
I just put my moms pc together and i am not getting any video out.
keyboard lighting does go on also, if that is usefull info.
all fans start spinning tho.
First time this happens so i really dont know what to do.
I cant think straight atm, so if there is crucial info mising, pls ask
PS: im using the HDMI on the mobo.
I am here to learn, please correct me if im wrong or you see me putting bs on your screen!
https://linustechtips.com/topic/1027690-system-not-posting/
9 minutes ago, BelgianNoise said:
PC:
500GB 860 EVO SSD
a 450W psu
make sure all your power connectors are plugged up and display cable is good
https://linustechtips.com/topic/1027690-system-not-posting/#findComment-12247584
im sorry for the bad post :)
i got it working just by cursing at it. no actually reseating the ram did it for me.
https://linustechtips.com/topic/1027690-system-not-posting/#findComment-12247671
for me handeling it with care and as I call it the technicians hand work really well. good to hear it works now! don't forget to mark it solved!
https://linustechtips.com/topic/1027690-system-not-posting/#findComment-12247679
