Question regarding different types of power system
Solved by tikker,
Voltage difference most likely (110/120V vs 210/220/240V) and the device is either protecting itself from overvolting or it's fried from overvolting.
On 1/29/2019 at 1:17 PM, J.b091 said:She wants me to buy new heating pad from Amazon, but I want to be sure that it will work and it's not the case of incompatibility of power systems.
Just buy one from a European (Amazon) store, i.e. ones that are built for Europe's power network.
