I have problems with my Asus Geforce GTX 1060 dual oc 6GB
My fps is a lot lower than usual and my gpu usage is under 10 always i play games...
Plz help me :( i have used over 1000€ To my pc and i cant even play games because my fps is too low because games dont use my gpu.
https://linustechtips.com/topic/1025663-i-need-help-with-my-gpu-usage/
Go to power management and make sure to set it as high performance.
Also, go to Nvidia Control Panel and set the game there as "Full Performance" instead of "Optimal Power".
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
Are you tabbed out when youre getting that gpu usage reading?
Are you using multiple monitors and do you run the game in full screen windowed mode?
Have you done a CLEAN INSTALL  of the latest GPU drivers? I would download the latest ones and go to custom installation. Select clean install and dont install Geforce Experience unless you absolutely need to.
Go to windows power settings and make sure minimum processor state is 5% and max is 100%, cooling policy is active, and that PCIe link state is disabled.
How else you think he would take that screenshot?....
Main PC:
Case: TT P3
HTPC:
Just now, Alluz.h said:
No i am not
You had to tab out or pressed Windows Key to take that screenshot.
Main PC:
Case: TT P3
HTPC:
what is your cpu do you use and how much ram?
Here Is My Daily Driver. FEAR MY 180$ COMPUTER AND ALL IT'S RAW POWER.. (i'm Broke) I Get My Money From Doing Builds.......
I5-2500s
Chinese 3 90mm Fan Over Kill For A Non-Overclockable CPU.
8gb ddr3 Samsung.. 1333mhz
Gtx 750ti 2gb EVGA FTW Single-Fan
DQ675W-Motherboard
1tb W.D 7200rpm 64mb Cache HDD
Seasonic SS-350ET 350w Power Supply
Cooler Master Elite 343 Case.. OOOO Fancy...
pcpartpicker
https://pcpartpicker.com/user/TheUssLoliChan/saved/
1 minute ago, Alluz.h said:
I am running with Ryzen 5 1600 and 1x8gb 2133mhz
what setting are you playing the game?
I5-2500s
DQ675W-Motherboard
pcpartpicker
3 minutes ago, Alluz.h said:
Actually i  didnt need to but it is same if i am tabbed out or not. I have dual monitors so i can see it
That's fair. Have you tried setting it all to high performance and maximum power?
Main PC:
Case: TT P3
HTPC:
Yes i think so
Does it work now?
Main PC:
Case: TT P3
HTPC:
If it doesn't. It may be a driver issue.
Install DDU and uninstall drivers clean.
Then go to Nvidia website and download latest driver for 1060 from there.
Main PC:
Case: TT P3
HTPC:
could it be not enough power?
I5-2500s
DQ675W-Motherboard
pcpartpicker
Terrible advice. Good way to wear out your parts without actually fixing anything.
Multiple monitors, like he said he has...
You dont need to use DDU. The Nvidia installer has a clean install option, which is what i already recommended he do.
1060 only sips power, 600W is enough for like 780 Ti and 980 so for 1060 it will be plenty.
I couldn't quickly find the power requirements for Dual OC one, but EVGA one (1060) only wants 120W, so that's not much at all.
Main PC:
Case: TT P3
HTPC:
Not a terrible advice. You don't know what you're talking about.
Multiple monitors... Late to the party mate.
Yes he does. So I guess GamersNexus was testing broken 2080 Tis in a wrong way, cool mate. Apply to their team, they'll accept you on the spot!
Anyway OP:
If that doesn't work, try this: https://www.techadvisor.co.uk/how-to/pc-components/how-set-default-graphics-card-3612668/
You may be using integrated graphics, but not likely.
Main PC:
Case: TT P3
HTPC:
Anyway OP:
Thank you put ryzen 5 1600 doesnt have integrated gpu
