Best cooler for i5 9600k?
chi_chi_
Hey guys,
So I am thinking about getting an i5 9600k, which means I will want to overclock it. I was wondering, whats the best cooler (I put this in air cooler cuz you probably won't find a water cooler for my budget.) Speaking of budget, I would like to pay a maximum of around 75 usd. Perferably black to fit my build but I guess noctua works too.
I would recommend the be quiet! Dark Rock 4. Black cooler with black fan and solid performance.
CPU: Intel I5-7500
CPU Cooler: Cooler Master ML240
Motherboard: ASRock B250M PRO 4
Memory: 16GB Patriot Viper Elite
Gpu: Asus Dual 1060 3GB
Storage: Corsair 120GB M.2 NVME
500GB Samsung 860 EVO
1TB WD Blue
Power Supply: EVGA 500W 80+Bronze
Case: Phanteks P350X
Monitors: HP Omen 25in 144hz
and some 25in Acer
Keyboard: Corsair K70 LUX RGB
Mouse: Corsair M65 Pro
Headphones= VModa Crossfade Wireless(but used wired)
Speakers: Some janky speakers I jerry-rigged
I'd recommend the Thermalright Macho Rev. B or Scythe Mugen 5.
What case and ram are you using?
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
Moved to Air Cooling.
1 hour ago, chi_chi_ said:
@WoodenMarker
I'm using the fractal design meshify c mini dark tg.
As for ram, im using g.skill aegis ddr4 at 3000 mhz
Depending on how much you prefer to spend, good options include:
Kotetsu: https://pcpartpicker.com/product/7998TW/scythe-cpu-cooler-scktt1000
Windale 6: https://pcpartpicker.com/product/fvgPxr/fsp-group-windale-6-600-cfm-cpu-cooler-ac601
Ashura: https://pcpartpicker.com/product/GqTmP6/scythe-cpu-cooler-scasr1000
Macho Rev. B: https://pcpartpicker.com/product/4TCrxr/thermalright-cpu-cooler-machorevb
@WoodenMarker I'm actually thinking about getting the dark rock pro 4, it's very pricy but I can afford it and my friend has it, he has an amazing OC on it.
The DRP4 performs similarly to the Macho Rev. B but is great if you want an extremely quiet cooler. That being said, the Macho Rev. B is still pretty quiet.
Ok thanks.
How much do u think I can  OC with that cooler. Specs linked above
It depends on your luck with the silicon lottery but I'm guessing ~4.8ghz.
1 minute ago, chi_chi_ said:
what the silicon lottery?
When it comes to overclocking processors, every CPU is different. Imperfections during fabrication cause each CPU to have different limits in terms of clock speed.
FYI, you can use the Edit button instead of making a new post.
