Hey everybody,
I'm looking for some help building the best WORKSTATION PC for my money.  I know I probably want a THREADRIPPER in there and probably the THREADRIPPER 2950.  I can't spend more than $2,000 but i really would like if it were more toward the $1,500 range.
I edit videos, do some 3D modeling, make animations, record music and make graphics.  I know its a lot but I just know I need a really good workstation style computer to make it the best for what I need it for and I figured people in this thread would be able to help me better than anyone else!
Thanks in advance for everybody's help!!
What software do you use?
2950x still expensive, the 1950x just as good and the price dropped.
same 16 cores.
CPU: AMD - Threadripper 1950X 3.4 GHz 16-Core Processor  ($589.99 @ Newegg)
CPU Cooler: Corsair - H100i PRO 75 CFM Liquid CPU Cooler  ($109.89 @ OutletPC)
Motherboard: ASRock - X399 Phantom Gaming 6 ATX TR4 Motherboard  ($244.98 @ Newegg)
Memory: Crucial - Ballistix Tactical Tracer 32 GB (4 x 8 GB) DDR4-3000 Memory  ($199.99 @ Amazon)
Storage: Crucial - MX500 1 TB M.2-2280 Solid State Drive  ($134.89 @ OutletPC)
Storage: Hitachi - Ultrastar 7K3000 3 TB 3.5" 7200RPM Internal Hard Drive  ($79.99 @ Amazon)
Video Card: Asus - GeForce RTX 2080 8 GB Turbo Video Card  ($699.89 @ OutletPC)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Corsair - CX (2017) 750 W 80+ Bronze Certified ATX Power Supply  ($54.99 @ Newegg)
Total: $2184.60
Generated by PCPartPicker 2019-01-23 17:11 EST-0500
same 16 cores.
Total: $2184.60
Yooo, you are the man for this!! Thanks so much.  It’s a tad over my budget though lol is there anything I could cut back on?
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor  ($308.99 @ Amazon)
Motherboard: Asus - Prime X470-Pro ATX AM4 Motherboard  ($161.99 @ B&H)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3000 Memory  ($219.99 @ Corsair)
Storage: HP - EX920 1 TB M.2-2280 Solid State Drive  ($169.74 @ Newegg Business)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2080 8 GB WINDFORCE Video Card  ($706.98 @ Newegg)
Case: Fractal Design - Define C ATX Mid Tower Case  ($96.98 @ Newegg)
Power Supply: EVGA - SuperNOVA P2 650 W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($82.99 @ Newegg)
Total: $1807.55
Generated by PCPartPicker 2019-01-23 20:36 EST-0500
CPU Cooler: Noctua - NH-U14S TR4-SP3 82.52 CFM CPU Cooler  ($79.90 @ Amazon)
Motherboard: ASRock - X399M Taichi Micro ATX TR4 Motherboard  ($274.98 @ Newegg)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-2666 Memory  ($84.99 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive  ($57.99 @ Adorama)
Total: $1972.61
Generated by PCPartPicker 2019-01-24 00:31 EST-0500
