I was thinking about buying this pc at the end of the summer:
CPU: Intel - Core i5-9600K 3.7 GHz 6-Core Processor  ($259.99 @ B&H)
CPU Cooler: Corsair - H60 (2018) 57.2 CFM Liquid CPU Cooler  ($69.89 @ OutletPC)
Motherboard: Asus - ROG MAXIMUS XI HERO (WI-FI) ATX LGA1151 Motherboard  ($275.98 @ SuperBiiz)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($139.99 @ Newegg)
Storage: Western Digital - Blue 1 TB M.2-2280 Solid State Drive  ($124.87 @ OutletPC)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2080 8 GB AORUS XTREME WATERFORCE Video Card  ($899.99 @ Amazon)
Case: Lian-Li - PC-O11 Dynamic (Black) ATX Full Tower Case  ($133.81 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 850 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.89 @ OutletPC)
Other: Vive Headset and Wireless ($800.00)
Total: $2869.30
Generated by PCPartPicker 2019-01-23 14:12 EST-0500
I'll have about $3000 USD, and was wondering if there was any changes to be made? I only have a 1080p/144hz but I am planning on upgrading that down the line. Mostly will be used for gaming and recording game play, and light 3d modeling and animation in maya. Also, will the graphics card fit in the case? Any help is appreciated!
https://linustechtips.com/topic/1024985-first-build/
If you plan on recording gameplay and doing 3d modelling, I would switch to 8700k/9700k.
Don't buy 120mm AiOs, they're generally worse in performance when compared to similarly priced air coolers.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1024985-first-build/#findComment-12224330
Swap your current cooler for the dark rock pro 4 (or non pro variant if you dont have enough money to spare); that mobo is hella overkill, the gigabyte z390 Aorus Pro will more than enough for the cpu; get the G2 model of the psu cause its better; and as for the gpu and case, check the dimensions, its not hard
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/1024985-first-build/#findComment-12224331
9700k's lack hyperthreading unfortunately so a 9600k ought to do him fine unless he needs hyperthreading then he's gotta get an 8700k. Intel really wants to fuck us over by forcing us to purchase prosumer CPU's like the 9900k to get hyperthreading.
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
https://linustechtips.com/topic/1024985-first-build/#findComment-12224360
Still 9700k got 2 more cores compared to 9600k. But you're totally right, Intel is screwing us over with 9th gen chips xD
https://linustechtips.com/topic/1024985-first-build/#findComment-12224369
You are going overkill on the PSU, 650W is more than enough, 750W is the max I would go for. And your motherboard shouldn't cost more than your CPU, especially with an Intel system. Also, the H60 is a terrible cooler.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1024985-first-build/#findComment-12224377
The Louvre
https://linustechtips.com/topic/1024985-first-build/#findComment-12224392
Thanks, I switched to a dark rock pro 4 for the cooler, the MSI MPG Z390 GAMING EDGE mobo, and a supernova g3 750w psu.
https://linustechtips.com/topic/1024985-first-build/#findComment-12224395
I recommend this:
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1024985-first-build/#findComment-12224419
Personally I would dramatically increase your HDD storage to a 3 or 4Tb drive, especially if you're game recording and video editing you'll go through a huge amount of space fast. Also, I'm pretty sure that's not a nVME m.2 drive so you're losing out on the performace gains there, cheaper to just get a 2.5 inch SATA SSD. I would also suggest a motherboard without WiFi for cheaper, unless you really need WiFi and lastly, for about 30 bucks cheaper, you can pick up a Ryzen 7 2700X 8-Core 16-Thread processor.
https://linustechtips.com/topic/1024985-first-build/#findComment-12224458
