Just now, sohail14 said:
can you tell me some example games ??
Counter-Strike and GTA 5 I believe.
Main Computer :
CPU:
Ryzen 5 2600x (STOCK)
GPU: Evga GTX 1060 3gb (STOCK)
RAM: Geil Potenza 8gb
SSD/HDD: WD green 120gb SSD/ 1 TB HDD
MOBO: Asus x470-Plus Gaming
PSU: Evga SuperNova 650 P2
Cooling: Antec 120mm liquid cooler
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219441
I believe CSGO (if that’s the CS you mean) is a CPU intensive game, so a better cpu would be best
edit: oh yeah I read this whole thread wrong
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219446
3 minutes ago, sohail14 said:
does high cpu really a matter ??
Only in  CSGO you will really see a huge difference if you were to upgrade the CPU, The GPU wouldn't really do anything in that game.
But the GPU would impact most games, the newer ones anyway.
Main Computer :
CPU:
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219459
7 minutes ago, Zandvliet said:
It usually depends on the game. ACOd is mainly GPU bound and lesser CPU bound. I guess a better CPU will help maybe a couple of fps.
Odyssey is definitely a CPU demanding title.
Sure, CS:GO is CPU demanding title too, but we are talking about game engine from ~2006, running at over 200 FPS.
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219462
I'm not saying it's not. But the GPU is more important compared to the GPU.
Another game I can think of is Planet Coaster. Not sure about others, I don't play that many different games.
"To the wise, life is a problem; to the fool, a solution" (Marcus Aurelius)
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219470
why the people always prefer high end cpu for gaming ??
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219475
A better CPU would improve your performance in Battlefield V multiplayer by a lot.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219476
This is incorrect, AC Odyssey and Origins both are very taxing on the CPU, in fact when I play AC Origins I am limited by my i7 8700 before the GTX 1080 Ti is an issue..
OP, whether or not you'll have more fps with a better CPU depends if you're limited by it rather than your GPU, primarily speaking.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219486
11 minutes ago, Quadriplegic said:
~2006
Source is from 2002.
Still not as bad as Fallout 76 though.
Personal Desktop":
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219490
Prevent Bottlenecking the GPU
Main Computer :
CPU:
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219510
Really? I'll check later tonight. Never noticed it before. Running 7700k and 2080.
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219556
Try walking around Alexandria in Origins, there are some places in there I'm certain you'll see your 4 cores maxing out.
Then again it used to be worse before all the patches.
Personal Desktop":
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12219567
On 1/22/2019 at 8:44 AM, sohail14 said:
i have i5 6402p does this enough for 1070 ??
http://www.tomshardware.com/answers/id-3670977/gtx-1070-6402p-bottleneck.html
Someone responded
"Sorry but this is to be expected, any system can bottleneck in the right circumstances. Your cpu is a lower end i5 from 2 generations ago and by current standards is about low end i3 level. The cpu heavy games you mention can all benefit from more than 4 cores/threads, it is just the way newer AAA games are going.
You could upgrade to a 6700 or 7700 (ensure latest BIOS)."
Hope this helps.
Main Computer :
CPU:
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-12223546
  • 1 year later...
If the single thread cant help the gpu to keep up, is it can affect fps lower and minimum fps?
Ryzen 5 2600 / MSI B350 Tomahawk / GALAX RTX 2060 6GB (1-Click OC) / Corsair Vengeance LPX 2666Mhz 8x2GB / ADATA SX6000 LITE 512 M.2 NVME / KLEVV 128 GB SATA / Seagate Barracuda 2TB 7200rpm / Seasonic Focus Gold 550W / Tecware Nexus C
Upgrade Plan: CPU: Ryzen 5 3600 RAM: GSkill TridentZ RGB 3200MHz/3600MHz MB: MSI B450 TOMAHAWK MAX
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-13564832
On 1/22/2019 at 5:46 AM, Earnist_ said:
no its not odyssey is very gpu dependent
Odyssey is a game that requires both a strong CPU and GPU to play.
A slow/narrow CPU will manifest in low fps even with a powerful GPU.
Likewise, a 9900k with a 1060 won't do well.
It's one thing to say that the game needs a fast GPU, it's a different thing to say it doesn't reply on CPU as much as GPU.
It needs both.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-13564851
It needs both.
year and a few months to late
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-13564923
gdi i got had - who bumped this
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-13564953
https://linustechtips.com/topic/1024495-will-cpu-increase-fps/#findComment-13564957
