*HELP* MY PC IS IN A BOOT LOOP!
5 minutes ago, Rowan Schaack said:Its very weird because the PC can boot into windows occasionally but only in like 1/30 attempts and it can only reach the post screen in like 1/10 boots! this has left me baffled.
Hmm.. Have you tried reseating your CPU? There's a few troubleshooting steps, and it sounds like it could very well be a hardware issue if it's not able to complete POST and get into the BIOS first. I had a computer a few days ago that did the same thing, and it ended up being caused by a badly corrupted and failing hard-drive, believe it or not.
Try unplugging all non-essential devices, so this would be only: motherboard, CPU, 1 stick of RAM, power supply and anything needed just to boot to BIOS. If it fails, narrow down what the issue is: is there physical damage on the motherboard? Bent pins in the CPU tray? RAM isn't working but the other stick is? Try troubleshooting this way. Add one thing to the system once it's certain that you have known good parts, and build your way back up until something doesn't work.
