Pc Konfi
1. Antec Perfomance P110 Luce - Midi Tower - ATX - ohne Netzteil
2. MSI B450 Gaming Plus - Motherboard - ATX - Socket AM4
   USB 3.1 1gen, USB 3.1 2gen, Gigabit La, Onboard-Grafik, HD-Audio(8-Kanal)
3. CPU AMD RYZEN 5 2600
   3,4 Ghz/ 3,9 Ghz, 16mb l3 cache, 65W, Socket AM4
4. Cooler Master MasterAir MA410P - Prozessorkühler
   120mm, Aluminium
5. G.skill AEGIS - DDR4 - 2x8Gb - DIMM 288 - 3000 Mhz/ PC4 - 1,35 V - ungepuffert
6. ASUS ROG Strix rtx2070 - A8G - Gaming - Advanced Edition,
   8Gb GDDR6 - PCle 3.0 x16 - 2xHDMI, 2x DisplayPort - USB - C
7. Samsung 860 EVO SSD 250GB SATA
8. 1TB Blue 64mb sata III
   6 GB/s - 5400rpm
9. Netzteil 600W
10. WinPro
https://linustechtips.com/topic/1023307-anything-wrong-with-dis-conf/
English?
Well I am german too but not everyone is.
PSU model?
5400 hdd sucks, go for a 7200rpm HDD
The rest is ok i guess, depending on the prices tags.
Budget? Purpose? Monitor resolution and refreshrate? What kind of games?
no clue where that PSU we dont really have a name on places on the handgranade to will last you forever scale so id probably get something else
Builds:
21 minutes ago, gvCL1910 said:
whats the difference between 5400 and 7200 rpm
Revolutions per Minute = Umdrehungen pro Minute
Usually more rpm = faster read and write speed (very simplified)
5400 hdd are usually the slowest you can get.
Just get a 2600 without X and take the 5 minutes it takes to Google it and overclock it yourself for 2600x speed
PCPartPicker part list: https://de.pcpartpicker.com/list/BLtQ29
Price breakdown by merchant: https://de.pcpartpicker.com/list/BLtQ29/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor (€157.90 @ Alternate)
CPU Cooler: ARCTIC - Freezer 33 eSports ONE (Black/White) CPU Cooler (€29.99 @ Amazon Deutschland)
Motherboard: Gigabyte - B450 AORUS PRO ATX AM4 Motherboard (€109.99 @ Amazon Deutschland)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory (€107.90 @ Amazon Deutschland)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive (€69.90 @ Amazon Deutschland)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Video Card: Gigabyte - GeForce RTX 2070 8 GB WINDFORCE Video Card (€521.00 @ Amazon Deutschland)
Case: NZXT - H500 (Black) ATX Mid Tower Case (€79.90 @ Caseking)
Power Supply: be quiet! - Pure Power 11 CM 500 W 80+ Gold Certified Semi-Modular ATX Power Supply (€71.99 @ Amazon Deutschland)
Total: €1148.57
Generated by PCPartPicker 2019-01-19 18:38 CET+0100
Check Geizhals.de for cheapest prices. Usually it is mindfactory.de but because pcpp does not realize that you can order without shipping costs between 0-6 am it does not pick it up.
You need to provide a make and model for the psu. It is one of the more important components in a build.
Unless there are specific features of Windows 10 Pro that you need, get the Standard (Home) version.
There is a 7200 rpm version of the 1TB WD Blue. It would be a better choice in this situation.
Is the memory F4-3000C16D-16GISB?
